Are these pistons done for?
  • Zaun
    • Dec 2009
    • 179
    So picked up a non running 325ix. Guy claimed low compression was cause for no start. I was going to use the body to move my 2.7 into it, but wanted to try and get it running before i did the swap. previous owner said it has a rebuilt head on it. Anyways after replacing several items (Rotor/cap, fuel regulator, main and fuel relays) I got it to start. Ton of white smoke. so i figured id pull the head to check the headgasket and have the head checked at a machine shop.
    Well now i see why the previous owner had tried putting a rebuilt head on. Had to have broke a timing belt and tried to run it. #1 piston is hammered on (all the others have lighter marks. Anyways wanted to see what you guys think, have the head checked out at machine shop and then try a new head gasket (he had put a VR one on) or are these pistons done for. Some pretty gnarly hits. Oh compression was 1-6 was 120,90,120,120,90,120
    Pretty sure there probably done for but wanted to see what other people think.
    [IMG][/IMG]
    No actual holes in the piston and the pictures look way worse, then again it is pretty bad haha.
  • AndrewBird
    The Mad Scientist
    • 11898
    Picture isn't working for me.
    • TobyB
      • 5265
      Nor me.
      Pistons can take some abuse, but the edges can't- the ring lands will get compressed
      and the rings will stick.
      This is why a leakdown test is good after a compression test- if you had
      leaking by the rings, you'da known the valves were OK.
      t
      • Zaun
        • Dec 2009
        • 179
        Thanks andrewbird...looking into that..Fixed the picture...Will take more in the morning..Gonna catch some zzzzs
        • jeffnhiscars
          • Jun 2011
          • 6011
          I think that piston will develop hot spots. If it were mine I wouldn't use it.
          Alice the Time Capsule
          • Zaun
            • Dec 2009
            • 179
            im actually thinking that cylinder may have a crack, wait and see what the machine shop says about the head.
            • 101
              • Jul 2011
              • 764
              I would not use that piston either.
              101
              The E30 collection:
              1987 325es M52 - Schwarz / Taurus Red Sport (son #2's)
              1987 325is - Delphin / Black Sport (son #3's)
              1987 325i Convertible - Triple Black
              1989 325iX Coupe - Diamondschwarz / Black Comfort
              1990 325iX Coupe - Sterling Silver / Grey Sport
              1981 Fiat 124 Spider 2000 - Green / Tan
              1998 Volvo V70 GLT - White / Tan
              1998 Volvo S70 T5 manual - White / Taupe
              2001 Ford Windstar - Silver / Grey (parts hauler)
              2006 Lexus GX470 - White / Tan (tow rig)
              • Ether-D
                • Sep 2011
                • 2838
                The bottom of that piston is destroyed. Not at all worth risking it. I have a stack of m20b25 Pistons if you decide you want to replace that one. The block is likely scored as well though. Good luck.
                Originally posted by Andy.B
                I was born on 3/25…
                • SkiFree
                  • Jun 2011
                  • 2766
                  I would not reuse that piston and agree with what others have said.
                  Lastly, as I've said before. Timing belts don't just "break" unless it is well past the service interval. Sound like your swap timing just moved up.
                  For curiosity's sake, please keep us informed on what the machinist finds.
                  ADAMS Autosport
                  • Zaun
                    • Dec 2009
                    • 179
                    This ix has 170k on it..I didnt pick the car up from the owner, i had to work so i sent a friend to pick the car up sight unseen to me(and i knew not running). So I havnt gotten a whole lot of info from the previous owner, and my friend that went didnt really get a whole lot. He just looked at what i told him to look for and told him ignore the engine lol. Im going to take the head to machine shop hopefully Friday. That way i can at least see if this head is good or not and go from there.
                    Haha yea swap timing just got moved up...have to find a friend that will let me do it at there place. Current living arrangements do not allow it.
                    • TobyB
                      • 5265
                      Oh, ug-
                      that's a lot of damage- I like the valve imprint!
                      I wouldn't put a head back on that, either.
                      Sorry.
                      t
                      • stonea
                        • 2892
                        Originally posted by Zaun
                        So picked up a non running 325ix. Guy claimed lowed compression was cause for no start. I was going to use the body to move my 2.7/2.8 into it, but wanted to try and get it running before i did the swap.
                        FYI, ix blocks are ix specific. I've heard that you can convert a regular M20 block to a ix block, but I haven't seen proof yet. Not to say it can't be done, but I just haven't seen documentation.
                        My Garage
                        Feedback
                        Instagram: Stone.Hopkins
                        • Zaun
                          • Dec 2009
                          • 179
                          Yep! finding that out. I had read that i could, but cant find anything on it. Looks like the mounting points are different on the block...So i may end up having to build an ix block. Still trying to find research and plan out what im going to do. Took the head to local machine shop to have it checked out. Even if its good, and an actual rebuilt head like i was told by the previous owner, Im still probably going to use my head off my other motor due to all the machine work that has gone into it.
                          Really kinda a bummer because i was thinking i could just switch out the oil pan and pump and be good to go...unfortunately not the case lol
                          • The Dark Side of Will
                            • Jun 2010
                            • 2796
                            The only difference in the block castings is the location of the dip stick. The blocks are otherwise identical. The mounts are in the same locations.
                            The iX oil pump turns the opposite direction from the RWD oil pump, so you need to use the iX intermediate shaft (driven by the timing belt) and oil pump drive shaft, as the gears are cut with opposite pitch relative to the RWD gears.
                            As long as the top ring is still free, that piston can be reused in a stock application just fine. Don't boost it, though, as all the ridges are potential hot spots.
                            • jeffnhiscars
                              • Jun 2011
                              • 6011
                              However, once you pull that piston to check the ring lands there is simply no good reason to reinstall it.
