Das Beast: My E30 track / street build
  • zwill23
    • Jul 2015
    • 615
    #1501
    Originally posted by dvallis
    Community poll. Guess what this is and what's missing.
    We caught it before anything bad happened. Will replace all 4 with aircraft grade shank drilled bolts & cotter pins.
    Always nut & bolt your track toys.
    Those outer eccentric bolts are a pain in the ass to keep tight, a few of us in the Austin area have had issues with the bolts coming loose and requiring a re-alignment.
    I needed to go back to Soulspeed for an alignment twice before getting it right. I recommend jacking the car up and ensuring the nut is tight yourself after having the alignment done, the bolt orientation is also important to ensure tightness. The nut should face toward the center of the car, and the eccentric bolt head to the outside of the car, that way you can really crank on it to get it tight.
    • dvallis
      • Oct 2015
      • 1472
      #1502
      We actually re-bored the frame, replaced the bushings and run a tight tolerance non-eccentric bolt. We measured the camber as about 1.5 degree fixed if I recall, with a slight toe in. See way back around page 35. It was secured with a nylon lock nut but still fell out. We're further upgrading to a shank drilled bolt like this, with cotter pin and nylon lock nut. Impossible for that to fall out.
      "And then we broke the car. Again." Mark Donohue, "The Unfair Advantage"
      1987 E30 3L Turbo Stroker Das Beast
      2002 E39 M5
      • zwill23
        • Jul 2015
        • 615
        #1503
        Ahh okay, awesome! That's seems much more robust than the eccentric bolt method, carry on!
        • Digitalwave
          is a poseur
          • 6284
          #1504
          Impossible to fall out, but it can still loosen.
          RISING EDGE
          • ForcedFirebird
            • Feb 2007
            • 8300
            #1505
            The only snag about putting the bolts inboard is you have to pull the sub frame to remove a trailing arm. I leave the nut on the outside and use a "S" shaped starter wrench to tighten them.
            john@m20guru.com
            Links:
            • dvallis
              • Oct 2015
              • 1472
              #1506
              Thanks for the tip Bird. We put the bolts in with subframe installed so nuts must have been on the outside, Will take some pics when we redo it this weekend.
              2002 E39 M5
              • citizen_insane
                • Jan 2013
                • 216
                #1507
                Thanks for reminding me I need to check mine again...2 days after I put the car back on the ground (sigh). Glad you caught it before anything bad happened!
                • dvallis
                  • Oct 2015
                  • 1472
                  #1508
                  AN8-37 8740 alloy steel cadmium plated hex head shank drilled aircraft bolts arrived. They are 1/2-20, 3-31/32 length. (our frame is bored for 1/2" bolts)
                  Time to upgrade the trailing arms.
                  Started Ok
                  Drifted in fine with a slight bit of BFH.
                  Finishing touch. Cotter pins. The outboard nut is kind of a beatch.
                  Inboard was easy. Rinse & repeat.t
                  I registered the car with a TXTAG so we could haul ass around our 8 lane 85 mph tollways. Woo! Unsurprisingly, Das Beast handles much better with four trailing arm bolts. Handles great in fact. Rear end is totally planted, even under deceleration. Front does not float at all. The weird handling artifacts we experienced were obviously due to our loose trailing arm. What saved us was all the reinforcement back there. (Welds, plates, beefy sway bar etc) We had enough points of attachment to keep everything in place.The aircraft intercom was very useful for discussing all this as we went. By the way, clutch is holding perfectly now that it's broken in. No slipping, even for 5th gear WOT 20 psi pulls.
                  Time to start really working on the suspension now. We're going to dial in the ride height, corner & cross weights, toe and camber. Anyone have a used race scale for sale?
                  This little guy visited while we were wrapping up.
                  2002 E39 M5
                  • Elysian
                    • 674
                    #1509
                    130 is a lot of fun, we need more 85mph roads Only time I ever go on there is when I'm going to a hockey game in Cedar Park and running late.
                    • dvallis
                      • Oct 2015
                      • 1472
                      #1510
                      Onward with suspension setup. We want to be able to set up the car at a track if required, so "take it to a shop" is not on the agenda. There are a huge number professional and DIY alignment tools out there. No two of them alike apparently.
                      To start with, we've got one of these. Nice Longacre camber/caster gauge. That's some of the problem solved.
                      Next we'll make a ride height and toe alignment custom tool for the E30. Starting with 3 x 6' pieces of 1" x 1/8" angle iron. Make sure the inside radius between flanges has a lot of "meat" like this one. Means the stick will have a high "K factor" ensuring excellent rigidity and straightness. You can get them at Lowes for $15 each.
                      We picked up this handy tool at a welding shop several months ago. I knew we'd need it some time. Lets you weld bar stock at perfect 90 degree angles.
                      We cut 4 pieces, 13 inches long and notched them like this.
                      Tool gives us a perfect join. Rob got out the MIG and went to work.
                      Here's the end result. Two "C" shaped pieces each for the front and back. They will bolt directly onto the bumper supports like this. You can probably guess where this is going. Add some fishing line and we'll have a perfectly repeatable string box to measure toe and ride height.
                      Must be wildlife weekend. On the way home we rescued a large turtle walking across a four lane road at Shoal Creek. Big guy tried to bite me once but settled down when he realized I wasn't trying to eat him. Swam away happily in the creek
                      To be continued ...
                      2002 E39 M5
                      • dvallis
                        • Oct 2015
                        • 1472
                        #1511
                        Suspension musings ....
                        Could not find a decent write up of the math for string box alignment so here it is. There's a huge amount of confusion on the internet around using ASIN, ATAN or whatever to figure out toe per wheel, total toe, whatever. Instead of blindly relying on some internet calculator, or "I read that some guy said" here's the fundamental math.
                        Negative toe is OUT
                        Negative camber is IN
                        Positive caster is wheel AHEAD of strut tower
                        Front positive toe = better stability
                        Front negative toe = faster turn in but less stability
                        Rear positive toe adds under steer
                        Rear negative toe adds over steer
                        Adding camber also adds toe IN. Adjust camber first
                        More caster keeps tire contact patch level when wheel turns
                        Too much caster causes corner jacking (>10 deg on E30)
                        More caster dynamically adds camber as the wheel turns
                        May have to revisit the rear suspension depending on measurements. See this post for details and pics on adjustable rear suspension. Need to dig those IE parts out of the garage. Don't forget to add the Chrome photobucket fix from page #1 of the blog.
                        Ground control caster adjustments
                        Longacre Camber Caster gauge instructions (Caster part is funky. Still don't understand it)
                        Some data for reference when we do the alignment.
                        E30
                        STOCK
                        SPEC
                        30
                        DAS BEAST
                        TARGETS
                        Front caster (deg) 8.5 ±0.5 9.0 10
                        Front camber (deg) -0.67 ±0.5 -3.5 -4.0
                        Front toe (in) 1/8" ±1/32" -1/16" 0.0
                        Front toe (deg) 0.3 ±0.08 -0.15 0.0
                        Rear camber (deg) -2.0 ±0.5 -2.5 -2
                        Rear toe (in) 1/8" ±1/16" 1/16" 1/8"
                        Rear toe (deg) 0.3 ±0.12 0.15 0.3
                        Thrust angle (deg) ±0.25 max 0.0 0.0
                        Steer ahead (deg) 0 0.0 0
                        E30 wheel base is 101.2"
                        2002 E39 M5
                        • citizen_insane
                          • Jan 2013
                          • 216
                          #1512
                          Those suspension settings look about right to me. I wasn't able to get more than -3.5° camber and 9° caster up front with my GC race adjustment plates, but I have stock shock towers, can't remember if yours are modified. Are you planning to use front roll center correction? I've got some extended ball joints I've been meaning to put in my car. My car isn't all that low, but the front end feels like it wants to give up a bit when I push it hard (unlike my other race car which is double unequal length A-arm up front).
                          • dvallis
                            • Oct 2015
                            • 1472
                            #1513
                            Thanks for the confirmation on setup numbers. Is the GC caster adjustable from underneath with the strut attached, or do I have to take the whole freaking strut off?
                            We're running this custom built coil over based on reinforced stock struts with ground control adjustment plates.
                            I haven't looked into roll center / bump steer correction yet, but it looks fairly simple on this car. Just a kit that adjustably lowers the tie rod ends. Any experience with the Garagistic or Ground Control kit? They look pretty solid.
                            2002 E39 M5
                            • Digitalwave
                              is a poseur
                              • 6284
                              #1514
                              Regarding the alignment (if you are seeking any advise that is), you'll probably just max out the camber and caster in the front. You don't have to take anything apart to adjust the caster. Just loosen the 3 top bolts that hold the plate to the shock tower and push them all the way to the back of the car.
                              You'll probably want a little more than -2* rear camber; -2.5 to maybe -3 at the most. If you can get -1/8" rear toe that that would be a good number. Nobody runs front toe in on a track E30. Either 0 front toe or 1/16" toe out would be a good starting place.
                              Check out MRT Engineering, they have the nicest E30 bump steer kit I have seen, with real engineering behind it. Second choice would probably be SLR Racing here in Florida. I wouldn't buy anything from Garagistic; they just copy other's designs and sell them for bottom dollar. They typically get a lot of complaints for poor fit and finish.
                              RISING EDGE
                              • dvallis
                                • Oct 2015
                                • 1472
                                #1515
                                ALWAYS taking advice. Thanks. :-) Will be scrutinizing the front shock tower plate later. Caster adjustment makes sense looking at this picture of the GC plate.
                                Are you adjusting the rear toe and camber with eccentric bolts? I read so many horror stories about them or the IE kit coming loose we decided to go fixed and "run what we got" in the rear.
                                I've still got this IE kit.
                                2002 E39 M5
