Das Beast: My E30 track / street build
  • dvallis
    • Oct 2015
    • 1474
    #1546
    Haven't posted in a while so thought I'd share what we've been up to. Scale project is coming along well.
    Load test. No deformation of platform
    At the electronics lab. No load voltage output 0.6 mV
    Output is 3.2 mV with me standing on it
    Adding the circuitry. Scale measures the analog voltage locally with a 24 bit ADC, converts to digital data which is sent over an ethernet cable to the main box.
    Here's the digital data. Each rising edge of clock samples a one or zero in the 24 bit word.
    Putting it all together. You can see digital data for applied weight displayed on the LCD
    Better load capacity and more accurate than your average bathroom scale :-)
    Building the brain box
    Adding keypad, power connector and scale connectors. Dust caps are a nice touch.
    I'll use chopped and stripped ethernet cables to break out wires on the inside of the plugs
    Adding the MCU board
    LCD gets mounted on top with standoffs
    So, there it is. Looking good. Lots of wiring to do now, and more code to write.
    "And then we broke the car. Again." Mark Donohue, "The Unfair Advantage"
    1987 E30 3L Turbo Stroker Das Beast
    2002 E39 M5
    • Digitalwave
      is a poseur
      • 6293
      #1547
      That is awesome, but also seems like more work than it would be worth (time = money and all that).
      RISING EDGE
      • dvallis
        • Oct 2015
        • 1474
        #1548
        It's a hobby. Got anything better to do during COVID? :-)
        2002 E39 M5
        • dvallis
          • Oct 2015
          • 1474
          #1549
          Scale is nearly done. Need to rinse & repeat three more weight platforms. Turned out good. We weight the Beast soon!
          2002 E39 M5
          • dvallis
            • Oct 2015
            • 1474
            #1550
            Weight scale finished. Nothing ELSE to do during COVID. :-)
            Drumroll .... Here's the weight with half tank of gas. So 2760 dry.
            Here's the balance with 230 lbs of simulated me and gear in the driver's seat. Took some adjustment on each of the corner springs but we got a pretty good setup. 50/50 front/rear, left/right and 50/50 cross weight.
            We're taking it to Harris Hill for a test & tune in the next couple of weeks.
            2002 E39 M5
            • Digitalwave
              is a poseur
              • 6293
              #1551
              Very good balance numbers. Actually, some of the best numbers I've seen on an E30. Surprisingly heavy though! I just balanced my car again 2 weeks ago and it came in at 2,348 (wet, but without driver).
              RISING EDGE
              • dvallis
                • Oct 2015
                • 1474
                #1552
                That makes sense if you look at these numbers.
                Here's my weight with cage, but without turbo etc. Pretty close to what you're at.
                Then add other performance parts that weigh more than stock.
                Then with me in the seat :-)
                Looks like I'm ST3 in NASA, which is fine. Looking forward to running.
                2002 E39 M5
                • Digitalwave
                  is a poseur
                  • 6293
                  #1553
                  That's interesting to see it broken down. I have about 40ft of tubing for my half cage, but otherwise have most of the other stuff save for the turbo kit and diffuser (both of which are heavier than I expected to be).
                  In Florida you'd probably need to be running 275 width Hoosier R7s and drive the absolute piss out of the car to hang in ST3, but no matter what, I am sure you are going to have a shit eating grin when you finally get to race this thing.
                  RISING EDGE
                  • dvallis
                    • Oct 2015
                    • 1474
                    #1554
                    That makes total sense. With a half cage and similar weight reduction you clock in right around 2,340 on my spreadsheet. Very cool for the numbers to line up.
                    Will be doing a lot of shakedown this weekend. Alignment tweaks mostly. Also adding hood vents next week. Gotta get the HOT out. :-)
                    2002 E39 M5
                    • ForcedFirebird
                      • Feb 2007
                      • 8300
                      #1555
                      Fun note: 1.5" .120" DOM wall tubing weighs more than 1.75" .095, even though they both spec for the same vehicle weight. ;)
                      john@m20guru.com
                      Links:
                      • dvallis
                        • Oct 2015
                        • 1474
                        #1556
                        This picture, just because finding oil leaks with UV fluorescent dye and "burn da eyes outta ya" UV lights is cool. Yes, we have safety goggles.
                        Minor seep from the top right front of the head. You can see it running down the side of the water pump etc. We replaced ALL those seals during the rebuild, so going to tighten the head studs and call it good.
                        2002 E39 M5
                        • dvallis
                          • Oct 2015
                          • 1474
                          #1557
                          Some of you may remember this:
                          Which is actually this:
                          I finally got around to re-programming the whole AIM system today, and it ALL WORKS. I'm frigging overjoyed.
                          Here is the "warmup" screen. Oil pressure and fuel pressure are coming from sensors separate from the ECU. Good to seen them working. Rest of the data is via CANBUS from the ECU.
                          The "crew" screen shows things my crew chief might want to know before I go tearing off into the wild blue yonder.
                          VBAT : battery voltage
                          IBAT : current from the battery
                          IALT : current from the alternator
                          IBUS : current on the main bus.
                          And great for setting brake bias!
                          FBRK : front brake pressure
                          RBRK : rear brake pressure
                          Just noticed my brake pressure sensors need zeroing. Easy stuff with AIM. TPS gets calibrated through Megasquirt.
                          Diagram for clarity
                          Suspension travel sensors are also working. Need to zero them.
                          Took the car to an "undisclosed test location" (aka Mopac Expressway) and did laps of a to remain nameless service road loop. Here's a cut of the data log from Race Studio. Really interesting to see what the car is doing under load.
                          So, with that all working I've got 30 semi-private laps of Harris Hill scheduled for next month. There will be an obligatory track school, "Are you an idiot" checkout ride, then time to get some data.
                          2002 E39 M5
                          • ForcedFirebird
                            • Feb 2007
                            • 8300
                            #1558
                            UV is fun. The stock ECU chip is a 255kb PROM, UV erase. Peel the sticker off, set it in the sun for a few days, and BOOM, blank slate. Amazing how photons can zap electrons out of memory. I have an old machine at the shop with 19kb of bubble memory...it holds about 350 lines of code.
                            EDIT: I LOVE the science, but WHEN CAN WE SEE RACE FOOTAGE?!?!?!
                            john@m20guru.com
                            Links:
                            • dvallis
                              • Oct 2015
                              • 1474
                              #1559
                              A frigging PROM? No way? I used to code on those back in the stone age. Had a little UV shoebox for erasing them. How do you re-code an erased E30 prom?
                              Track footage next month. Actual race footage? Soon ..... I have a new Bell M8 SA2020 helmet coming next week. Getting the HANS re-certified. Need a new suit but the old one should be fine for DEs.
                              2002 E39 M5
                              • dvallis
                                • Oct 2015
                                • 1474
                                #1560
                                Race Studio GPS data export into Google Earth. Pretty cool.
                                2002 E39 M5
