Das Beast: My E30 track / street build
  • dvallis
    • Oct 2015
    • 1472
    #1681
    Well, we are definitely BACK!
    Only thing today was figuring out the dreaded timing belt fuzz. Remember one of the issues was something eating our timing belt? Turns out it was screws for the distributor cap delete plate protruding into the belt way. Pulled the rad, top hoses and timing cover. Trimmed the screws. Problem fixed.
    It's idling great. oil is 25 psi hot. Fuel pressure 40 psi at idle. Nominal is 45 psi at 0 psi boost, but since idle is under vacuum it pulls down fuel pressure a bit. Perfect.
    Break in driving. Fuel pressure at 45 psi under throttle, 60 psi oil pressure. Water temp rock solid at 180. (After we burped the cooling system a few times) Oil pressure never goes below 25 psi under braking. No oil or water leaks.
    Next Steps are go get inspected, put break in miles on it, change out the oil then go for a dyno tune.
    Here's a longer walk around video.
    "And then we broke the car. Again." Mark Donohue, "The Unfair Advantage"
    1987 E30 3L Turbo Stroker Das Beast
    2002 E39 M5
    • Digitalwave
      is a poseur
      • 6281
      #1682
      Welcome back Das Beast!
      RISING EDGE
      • Elysian
        • 674
        #1683
        Just in time for cooler power making weather
        • dvallis
          • Oct 2015
          • 1472
          #1684
          Car is inspected, insured and street legal. Time to start putting on the break-in miles!
          2002 E39 M5
          • ADEN
            • 620
            #1685
            Curious of the way of breaking in: grandma route or drive it like you stole it lol.
            • dvallis
              • Oct 2015
              • 1472
              #1686
              Simple really. Drive it in a wide variety of speeds, engine loads and RPM. No WOT since our compression is higher, want to avoid detonation. Stay out of boost. After a 100 miles or so, we'll bring it to Boost Logic for a dyno tune. THEN get on it like a sasquatch. : - )
              2002 E39 M5
              • dvallis
                • Oct 2015
                • 1472
                #1687
                Tightened up some water & boost hoses, tensioned the throttle cable and calibrated the TPS. It was reading -35% to 50% so ECU did not know WTF was going on. Response is even better now, even though I'm only driving at partial throttle <%30. Put 30 more miles on it. Will smoke test again this week.
                Boost Logic shut down working on customer cars. It's R&D only now. Their tuner Roman moved to Dallas, opened his own shop with a four wheel dyno. Figuring out logistics on the tune next week.
                2002 E39 M5
                • dvallis
                  • Oct 2015
                  • 1472
                  #1688
                  We put the rest of our 100 break-in miles on The Beast yesterday. This thing is really strong off boost. Co-pilot kept me at partial throttle and out of boost, LoL.
                  We data logged the whole thing. Here's a sample. You can see the boost controller doing its job, boost coming on until I got out of the throttle.
                  Going to swap out the break-in oil then see about getting this thing dyno tuned.
                  2002 E39 M5
                  • dvallis
                    • Oct 2015
                    • 1472
                    #1689
                    Found our new tuner. We're taking it to Bardabe Performance here in Austin. He's got a Dynapack hub dyno and has a lot if experience using it.
                    We're changing out the break-in oil and filter this weekend for race oil, then off to the dyno on Tuesday.
                    2002 E39 M5
                    • dvallis
                      • Oct 2015
                      • 1472
                      #1690
                      Dumped the 0W break in oil today. Had some metal particulate as expected but nothing out of the ordinary
                      10 new quarts of Moly 10W60
                      Oil pressure was GREAT after warm up. In long sweepers and under straight line throttle I'm seeing 60 psi. At a "bus stop" 90 degree turns I'm still getting 40 psi full on the brakes. The new baffled pan with 60 weight is doing exactly what we need.
                      Dyno tune on Tuesday
                      2002 E39 M5
                      • Northern
                        • 5075
                        #1691
                        That's promising news! looking forward to the dyno
                        Originally posted by priapism
                        Originally posted by shameson
                        • dvallis
                          • Oct 2015
                          • 1472
                          #1692
                          Bolted to the hub dyno.
                          2002 E39 M5
                          • dvallis
                            • Oct 2015
                            • 1472
                            #1693
                            Cam gear threw a bolt and slipped. We were running 20 degrees retard. Nuke gear is getting deleted. We'll do a compression check to see if the valves were damaged. Deeper valve pockets may have saved us.
                            Better look at the timing marks
                            2002 E39 M5
                            • Northern
                              • 5075
                              #1694
                              I like the nuke gear vs the old ebay ones and a lot of people run them without issues.
                              I'd personally just fire some low/med strength loctite on the bolts and send it, but I also understand the urge to yeet the item that causes pain
                              • dvallis
                                • Oct 2015
                                • 1472
                                #1695
                                So who is actually running any mechanical advance to make more power. With what cam? I'm running a 284/272.
                                Let's hear a roll call.
                                2002 E39 M5
