Finally progress on the defogger. Main problem we needed to solve was the heater core outlets and bypass valve had to be on passenger side. Driver side is taken up by the wiper motor and linkage. That means long hoses in the cockpit from right to left that are always full of hot coolant. (Remember, it's a bypass valve. Coolant always flows.) We wanted to avoid that.
How do you keep coolant lines away from brake lines and wires? I got the solution in a 1 AM "Ah Ha!" Run coolant lines through the heater core. Copper even radiates heat and adds a few BTU to our core output.
You get a better idea from this view with the core in place.
We're going into the engine bay at the stock location. Why? Because it's the easiest place you can run coolant hoses to given everything going on in the engine bay. Believe me. We looked at every other alternate location. Just wasn't worth all the plumbing gyrations. Connections from heater core to bulkhead will be 5/8" ID formed coolant hoses that fit over the copper fittings.
