Das Beast: My E30 track / street build
  • dvallis
    • Oct 2015
    • 1474
    #1066
    Here's the finished diffuser.
    Bottom front view
    Bottom rear View
    Top front view
    Top rear view
    We'll paint it, then bolt it on.
    "And then we broke the car. Again." Mark Donohue, "The Unfair Advantage"
    1987 E30 3L Turbo Stroker Das Beast
    2002 E39 M5
    • 325e '87
      • May 2017
      • 503
      #1067
      I remember when you started and you meticulously weighed everything that you stripped from the car and I’m curious if you’re weighing every individual thing that you put back on the car? Just wondering and what your total is so far since you’re close to having it built.
      My son has the 1987 325e, 2 door, 5speed
      I daily the 1989 325i, 4 door, 5speed
      • Digitalwave
        is a poseur
        • 6299
        #1068
        Are you still planning on using this car on the street?
        RISING EDGE
        • dvallis
          • Oct 2015
          • 1474
          #1069
          Still going to use it on the street. Clearance for the diffuser is ok, but you wouldn't want to dive bomb over any speed bumps. Will be building scales, corner balancing and getting a final weight soon. Since we removed virtually everything from the car, my guess is we will still come in under 2000 lbs.
          2002 E39 M5
          • Digitalwave
            is a poseur
            • 6299
            #1070
            I'm sure you have enough ground clearance, I was just curious since the car is so hardcore.
            I'm guessing your weight is going to be more in the 2300-2400lb range, unless you have a lot of composite body panels + plastic windows that I missed. My 318iS slick top with an NA M20, carbon hood, carbon manual mirrors, half cage, essentially no interior (at least, less than you have), no sound deadening, and various other lightening methods is 2,400 even with 1/4 tank of gas. Your cage, engine bay w/ the turbo setup, dash setup with the HVAC system, brakes, etc. are all heavier than on my car. I'm definitely curious to see the outcome.
            RISING EDGE
            • dvallis
              • Oct 2015
              • 1474
              #1071
              Don't have my spreadsheet handy but there were a lot of weight saving measures. Deleted entire interior, tire well, sunroof, headliner, metal bumpers, HVAC, AC, power steering, ABS, headers, mech fan, floor tar trunk tar, gas tank, under body heat shields.
              Using fiberglass hood, elec fan, plastic bumpers, aluminum seats, lexan windows, lightweight exhaust, fiberglass dash, lightweight HVAC.
              Added cage, turbo, intercooler, fuel cell, diffuser, big brakes. I'm guessing closer to 2K lbs. Will revisit the spreadsheet.
              Will definitely be interesting to see the final number.
              2002 E39 M5
              • kronus
                • Apr 2008
                • 13032
                #1072
                cages are heavy. our racer (early chassis, totally stripped, no trunk, no spare well, no back half of the roof or rear bulkhead, windshield only, all panel reinforcements cut from doors and hood) was 2470 with 24gal.
                cars beep boop
                • Digitalwave
                  is a poseur
                  • 6299
                  #1073
                  I have all the same lightening you have done, besides the plastic windows (they probably save 40-60lbs?) and I have power steering. I have less weight added back (your turbo, big brakes, full cage, fuel setup looks fairly heavy). I'd be surprised if it was under 2,400. The scales won't lie, so we'll find out soon enough.
                  RISING EDGE
                  • kronus
                    • Apr 2008
                    • 13032
                    #1074
                    bugg breakz are light tho
                    cars beep boop
                    • dvallis
                      • Oct 2015
                      • 1474
                      #1075
                      Pulled the spreadsheet. Car weight was reduced by 822 lbs by removing things and/or substituting with lighter alternatives. We added about 275 lbs of turbo, fuel cell, cage and diffuser.
                      Looks like the curb weight will be about 2265. Plus me and some gas. LoL
                      2002 E39 M5
                      • dvallis
                        • Oct 2015
                        • 1474
                        #1076
                        Diffuser fully installed. Perfect fit. You can't see it in this shot but floor of the diffuser is flush with the bottom of the diff. Upper diffuser vent intakes are in line with the rear axles.
                        We moved on to the front end. Rebuilt each headlight with LED dual beam outboard and air intakes inboard. Reforming each housing and rebuilding the aiming mechanisms was a cast iron beeech.
                        Turned out good though.
                        We made it this far and called it quits today. Das Beast is finally starting to look like a BMW again.
                        2002 E39 M5
                        • litu
                          • 846
                          #1077
                          Very nice
                          https://www.facebook.com/Cry_77_IX-110483784967661
                          https://www.instagram.com/cry_77_ix/
                          • WestCoastEta
                            • May 2015
                            • 475
                            #1078
                            Diffuser looks money. I spent a few hours reading through this thread again and man, your work is meticulous and impressive. Looks like the finish line is in sight and I can't wait to hear this bad boy start up finally
                            • MrScuba
                              • Oct 2016
                              • 9
                              #1079
                              Kindred spirits
                              Here is a little something to fill in a lull in the action.
                              More wiring.
                              • 325e '87
                                • May 2017
                                • 503
                                #1080
                                ??? Everything ok down there?
