Das Beast: My E30 track / street build
  • dvallis
    • Oct 2015
    • 1472
    #1201
    First major post in a while. Beat the damn pneumonia and back in the saddle.
    Here's the punch list we have to complete before going to the tuner:
    1. Install 6 psi boost spring
    2. Clock turbo to 12:00 (done)
    3. Oil catch can
    4. Move oil pressure pickup to block
    5. Check timing
    6. Turbo blanket (done)
    7. Leak down test
    8. Boost controller
    Giant ass C clamp helped with the boost spring change over. New 6 psi spring sets the minimum boost. Solenoid valve sets maximum boost under control of the ECU.
    New oil feed line. It will get secured to the frame.
    Making the new remote oil pressure sensor line
    We love building custom hoses.
    Moved the oil pressure pickup to the OEM M12x1.5 fitting.
    Cold oil pressure is 60 psi at idle, 70 psi 3000 RPM. Pressure relief valve looks to be working.
    Once the car warms up, idle pressure drops to 30 psi. Good.
    Engine warm, 3000 rpm, pressure is 60 psi. Also good.
    Mechanical gauge agrees
    We cleaned up the timing mark and painted it. WTF does O/T mean in German?
    And finally, here's the timing check with a strobe on plug #1. You can't see the block timing mark from this angle so I highlighted it in red. Crank turns clockwise, so left of timing mark is advance. Looks to be about 10 degrees, which is what the spark map is set to for idle.
    "And then we broke the car. Again." Mark Donohue, "The Unfair Advantage"
    1987 E30 3L Turbo Stroker Das Beast
    2002 E39 M5
    • dvallis
      • Oct 2015
      • 1472
      #1202
      More good work today. Rob was up at dawn and installed the oil catch can. I like it. I can't find a definitive answer about needing a PCV valve between the cover and catch can or not. Seems to make sense you'd want the valve cover to vent, but not pull in air so the engine would maintain a better vacuum. Any comments?
      We re-visited the boot control solenoid before cutting hose for install. In the diagram below, boost pressure comes from the compressor housing to a tee. Middle of tee routes to top of the boost control valve diaphragm. (It's upside down in the picture) Pressure works against the spring until boost exceeds spring tension and the valve opens. Other side of the tee routes to the bottom of the valve diaphragm. As boost PWM duty cycle increases, it adds pressure to the spring side via path 1-2. At 100% duty cycle, air pressure on each side of the diaphragm is equal and the spring holds the waste gate closed. As the boost PWM duty cycle decreases, pressure vents from the valve diaphragm via path 2-3. Makes sense.
      Boost hose ready for the solenoid.
      Solenoid mounting bracket with rubber for isolation. Solenoid vibrates at 50 Hz so you don't want it directly bolted to the car body or it will vibrate like a snare drum.
      Solenoid mounted. Hard to see from this angle but it doesn't touch anything except the bracket and hoses.
      Charge hose back in place. Nice clean install.
      Finally, we did a compression test. Average for all 6 cylinders is 150 psi. Bentley's says spec is 142 - 156 psi. 1,3,4,5,6 are great. 2 is 6% low, which is Ok. 10% variance is the rule of thumb.
      1:150
      2:140
      3:155
      4:151
      5:155
      6:151
      Last thing left is rewiring the ECU for boost control. i.e. pull the damn bulkhead. Oh joy. Gonna have to wait until Rob gets back as its a two person job.
      2002 E39 M5
      • MrScuba
        • Oct 2016
        • 9
        #1203
        Glad to see you are back at it.
        We were worried about "our" car,
        • Bubbles
          • Sep 2015
          • 7
          #1204
          oberer Totpunkt (top dead center)
          • ForcedFirebird
            • Feb 2007
            • 8300
            #1205
            For the crankcase vent, you want to have the catch can between the valve cover and a vacuum source if you want vacuum on it. The way you have it set up, it's just venting to atmosphere, which works, but having vacuum is best.
            Often for a turbo setup, rather than just a filter, I will go from the valve cover, to catch can, to the pipe between the turbo and filter (not much vacuum there, but will have some) - or have even done a slash cut at the exhaust system to create a venturi effect.
            So, in short, no, you don't need any kind of PCV valve.
            Would have to read back at what camshaft you have in there, but 150 is a little low for a stock cam/compression. Just did a comp test on a 9.5:1 m20 with 272 cam here at the shop and it's 180 across the board (cam is also a few degrees retarded). Moreso, wonder why you got 140 on #2.
            john@m20guru.com
            Links:
            • dvallis
              • Oct 2015
              • 1472
              #1206
              Hey 'Bird
              Thanks for chiming in. We don't need no steenking emissions control so I'll leave the catch can as is, LoL.
              Cam is a Schrick 284/272
              ---lift 11.4 mm intake / 11.0 mm exhaust
              ---EO -246, IO -32, EC 26, IC 252 deg
              ---Intake / Exhaust overlap 58 deg
              I'd have to go back to my spreadsheet & see how those specs compare to stock. I'm guessing valves open longer could lower compression.
              No idea on #2. Rings are new, maybe that cylinder is taking longer seating?
              2002 E39 M5
              • ForcedFirebird
                • Feb 2007
                • 8300
                #1207
                Yeah, your cam is bleeding pressure at low RPM, your cranking pressure is good if you have the stock 8.8:1.
                PCV is not for emissions (originally), it was to bleed off positive pressure in the crank case (positive crankcase ventilation). In a running engine, combustion gasses leak past the rings and eventually fill the crankcase with pressure. This blows out gaskets as well as creating more resistance for the piston travel. If you think about how fast a piston moves up/down in an engine, air resistance gets serious. If you have perfect vacuum in an engine, then you eliminate said resistance. So, right now you have PCV, but, vacuum would be better. ;)
                There have been many trials for crankcase vacuum, here's a quick link from a Google search...
                Crankcase ventilation systems and the addition of a vacuum pump can swing positive crankcase pressures to zero (atmospheric) or even negative values.
                In the old drag racing days, slash cuts were used in exhaust systems, but once sound ordinances came about and mufflers were required, the back pressure limited the venturi effect, hence companies like Moroso developing belt-driven vacuum pumps.
                john@m20guru.com
                Links:
                • dvallis
                  • Oct 2015
                  • 1472
                  #1208
                  Good post John. I get it. Will look at re-engineering the catch system.
                  I think it looks like this: Hose from valve cover to one side of catch can, then from other side of can to intake. No filter on the can. Will pull a bit of vacuum on the head, but catch any oil that wants to blow out to the intake.
                  2002 E39 M5
                  • ForcedFirebird
                    • Feb 2007
                    • 8300
                    #1209
                    In a turbo setup, you will want the hose going to the intake side of the turbo, or, have a check valve of some sort...otherwise you will send boost into the crankcase.
                    john@m20guru.com
                    Links:
                    • 325e '87
                      • May 2017
                      • 503
                      #1210
                      Maybe he meant throttle body? I don’t know anything about turbo set ups and i get that the intake is pressurized, is there a throttle body?
                      My son has the 1987 325e, 2 door, 5speed
                      I daily the 1989 325i, 4 door, 5speed
                      • dvallis
                        • Oct 2015
                        • 1472
                        #1211
                        No. He meant tap between turbo intake filter and turbo compressor to pull some vacuum.
                        2002 E39 M5
                        • Digitalwave
                          is a poseur
                          • 6293
                          #1212
                          I just added a catch can to my NA car and in my research it echo'd everything Bird said, a little vacuum helps the VC ventilation to work properly. But it will work ok vented to atmosphere.
                          RISING EDGE
                          • dvallis
                            • Oct 2015
                            • 1472
                            #1213
                            Right. I meant "other side of can to intake between air filer & turbo compressor" not the intake manifold. Boosted catch can would not help performance LoL.
                            2002 E39 M5
                            • dvallis
                              • Oct 2015
                              • 1472
                              #1214
                              Finally got to the last bit before dyno time.
                              One inline fuse for the boost solenoid
                              Added a connector to the solenoid in case we have to swap it out
                              Turbo blanket on and boost controller wired up
                              Yeah. We really had to do this. Boost control solenoid gets wired into the Megasquirt option connector and a switched 12V supply
                              Fortunately we're good at it now. Bulkhead back together
                              And dash re-installed
                              Started it up and let the engine reach operating temp. Idles great, even without an ICV.
                              We're ready for the tuner. Going to drop it off on Friday.
                              2002 E39 M5
                              • 2mAn
                                SeƱior Mod
                                • 20625
                                #1215
                                Cant wait to see the results of the work!
                                Simon
                                Current Cars:
                                -1966 Lotus Elan
                                -1986 German Car
                                -2006 Volkswagen Jetta TDI
                                Make R3V Great Again -2020
