Das Beast: My E30 track / street build
    Don't you just love those "third hand" clamps for soldering?
    john@m20guru.com
    Links:
      Gotta have 'em. Just too much swearing and scotch tape otherwise. :-)
      "And then we broke the car. Again." Mark Donohue, "The Unfair Advantage"
      1987 E30 3L Turbo Stroker Das Beast
      2002 E39 M5
        Someone asked where I got this turbo drain extender. From eBay, here.
        Originally posted by dvallis View Post
        This damn thing finally showed up so I can start on turbo rework this weekend.
        2002 E39 M5
          Punch list complete
          1. Install 6 psi boost spring DONE
          2. Clock turbo to 12:00 DONE
          3. Oil catch can DONE
          4. Move oil pressure pickup to block DONE 30 psi warm idle, 60 psi warm 3K RPM
          5. Oil change DONE Mobile1 15W50
          6. Check timing DONE ~10 deg advance @ idle per spark map
          7. Turbo blanket DONE
          8. Compression test DONE 150 psi
          9. Install boost control solenoid DONE
          Back to the tuner
          2002 E39 M5
            Punch list complete
            Back to the tuner
            What wheel/size/offset and tire combo did you end up with?
              Start reading here
              2002 E39 M5
                You rock thanks
                  Update. Still in line for the dyno. Might be this week.
                  2002 E39 M5
                    :popcorn:
                    Cant wait for that update!
                    Simon
                    Current Cars:
                    -1999 996.1 911 4/98 3.8L 6-Speed, 21st Century Beetle
                    Make R3V Great Again -2020
                      More good brake info here
                      Blog is so huge I use google to search for things like this:
                      Das Beast massive brakes site:r3vlimited.com
                      Works great
                      2002 E39 M5
                        Hey there, tried sending you a pm but i don't know if you received it or not. I'm having trouble locating a decent machinist in Austin.. where did you take your motor? Thanks!
                          Hey, got your message but totally forgot to reply LoL. Machinist was Curtis Price. Good guy, might be retired now. I PMd you his phone number.
                          2002 E39 M5
                            Curtis just called me back. He's still in business so you're good to go.
                            2002 E39 M5
                              And this, because my dyno tune is still not done. Cars in front of us.
                              2002 E39 M5
                                Thanks a ton for the rec! I'm dropping everything off to him tomorrow.
                                Google is useless in this case. I tried calling "Precision Machining Company" which was the highest rated result for "automotive machine shop near me" only to find that they don't service automobiles.. and then maybe 10 more phone calls.. none of which made me comfortable. I figured I could trust someone you'd trust your motor with. :)
                                Anyway, build looks nasty, carry on
