2.7i swap no start
Yes I have a toothed pully as well as a b25 CPS, sorry for the late reply i havent been able to get to the shop lately, Ill be heading there tonight and ill let you guys know what happens.Comment
So I have no spark and the fuel pump doesn't turn on. I am going to try switching chips in the ECU as well as the CPS. The new CPS I ordered has an ohms reading of 1000 so I think that's wrong, I am going to put a used one on that gave me a reading of 500Comment
Bridged pin 30 and 87 on fuel pump relay, car fires right up. I have tried 3 different relays for the fuel pump and nothing ha worked only when I bridge them.Last edited by bluebeamer; 11-05-2015, 05:49 PM.Comment
Main relay ?Seat Shocks....I have passed the baton to John Christy from Ninestitch. Email John or Garrett at ninestitch1@gmail.com
Alice the Time Capsule
87 Zinno Cabrio barn find 98k and still smells like a barn. Build thread http://www.r3vlimited.com/board/show...20#post3455220Comment
There is no 85 on the fuel pump relay.
30 - hot at all times
87 - this actually goes to the pump
both 86 - hot during running or starting (cranking it over)We're in deep now boys
1988 325i SETA - Daily driver
1988 340iL - Track car
My M60 V8 swap thread here
[oo==OO==oo]Comment
If the DME doesn't see a good signal from the CPS, it won't ground the fuel pump relay circuit. It's a Bosch safety feature that's caused us all grief.
Clean the CPS head, be sure it's as close as possible to the trigger wheel, and triple-check the resistance. Should be 540 ohms +/- 10% between pins 1 & 2. The other pairs (1&3, 2&3) should have very high resistance, like 300Kohm or more.
Not that it matters, but you have the cam sensor on #6 plug wire too, right? Did you try to get some codes off the DME with a stomp test? Any water in that big harness plug under the intake manifold?Comment
i guess we have different troubleshooting guides
[oo==OO==oo]Comment
