I have recently completed my 2.7i swap, using a 2.5 head with a cam and 20lb injectors and a 2.7 block. I had an 87 325e so when I got my donor engine and wiring harness I got one from an 87 325i. I am using a 173 ecu with a sssquid chip in it built for the swap.
Engine cranks hard but will not fire, the fuel pump relay will receive power sometimes and sometimes it won't so I have jumped the relay so it will always come on.
I have tired or replaced:
2 different cps ( same problems sometimes fuel pump turn on sometimes won't and not firing)
Redid the timing ( produced a hotter spark once it was done but nothing)
Took fuel injectors out of head placed a towel under all of them and turned car over and fuel came out ( they must be getting a pulse)
Readjustaded all the valves ( they were a little tight so now back to specs)
Tired swapping ecu from my 89IX, ecu ended in 350 ( once done i had no spark at all which was weird )
Tried putting in the original chip for the ecu (same problems : intermittent fuel pump and no start)
Tried a different AFM
Any input would be amazing so confused
