Stock M20 deck height
  • mr2peak
    • 2388
    Ok guys, what is the stock deck height for an M20?
    I'm reading 206.2 in some places, 206.7 in others. Still other people are claiming 2.7 block is 206.2 and 2.5 is 206.7
    What's the verdict? Who has actually measured the deck height, and what did you find?
    Drive it hard. Maintain it well.
    A Topless Memorandum
  • digger
    • Nov 2005
    • 6171
    ive measured two b25 blocks recently both 206.2mm. even eta block wasnt 206.7, it was 206.0 iirc
    • mr2peak
      • 2388
      That's what I was thinking. M20 B25 8.8:1 pistons, stock crank and stock 135 rods sit at 206.7, 0.5mm over deck height according to your measurements. Sounds like people have been confusing the piston height with the deck height.
      So 206.2 it is. Anyone measure a stock block differently?
      • digger
        • Nov 2005
        • 6171
        you should always measure the block you plan to use anyway as it may have been machined previously and there may be some variations
        • mr2peak
          • 2388
          Of course. Assumptions bend valves, or worse!
