Water system
  • Marqueln23
    • Nov 2015
    • 12
    Water system
    So I did a coolant flush because the coolant inside the expansion tank was disgusting. Then I cleaned out the tank. I put new coolant in and it's dirty as hell again. And there is white residue on the cap. What is my issue? Should I get a new water system? Or how do I clean it?
  • estoguy
    • May 2013
    • 1087
    White stuff on the coolant reservoir cap could indicate a bad head gasket. Check your oil too... if it looks like coffee with cream in it, definitely the head gasket.
    Estoguy
    • modernist
      • Apr 2014
      • 283
      Keep on flushin'.
      1986 327i
      transaction feedback
      DIY thing
      meh
      • TobyB
        • 5298
        Yeah, I think the cleaning procedure here might have to start with Mr. Head Gasket.
        But do a few more tests...
        t
        • essi1553
          • Apr 2012
          • 440
          Whoever did the flush didn't use distilled water. Take the cap off, wash it, let it dry on a table or something and you'll get the same effect. I doubt you can get rid of it with another flush, don't think its a big deal as long as you car isnt suffering any other issues. Next timing belt clean it well and use distilled water. I don't know anything about chemistry but it looks like calcium or oxidation.
          • Kershaw
            • 11822
            Even if you clean the expansion tank, that's only one small part of the coolant system. You'd have to do multiple cleanings with distilled water to get it fairly clean. Jim Levie suggests cascade detergent or 6oz of oxalic or citric acid if your system is rusty for cleaning it out.
            AWD > RWD
            • modernist
              • Apr 2014
              • 283
              You could probably open the block coolant drain plug and put a garden hose into the expansion tank and leave the hose on for awhile, probably get rid of most of the disgusting crap that way
              I haven't specifically done that though, someone else should chime in
              1986 327i
              DIY thing
              meh
              • Kershaw
                • 11822
                I have. Engine runs awfully cold like that. Haha. I haven't tried the detergent method, but hot detergent sounds like it would clean better than just cold running water. It did an ok job though, iirc.
                I also have connected an air hose to the bleeder screw location and shot compressed air in there trying to clear a blockage. It definitely worked, but the blockage was now on the ceiling. Lol.
                AWD > RWD
