Annoying clunk/jerk from driveline.. any help?
  • digger
    • Nov 2005
    • 6196
    Reduced vacuum is what cam overlap ala 288 cam does. It can also cause drivability clunky running if using stock cast intake manifold and motronic on a motor not built around that sort of cam
    • TobyB
      • 5288
      Below 2500, if you snap the throttle closed, does vacuum spike, or stay low?
      Low would make me think burnt valves...
      t
      • jasonbk
        • Aug 2011
        • 555
        Thanks digger. It indeed has stock intake manifold and motronic. I didn't notice any vacuum spike in on/off throttle in low rpm.
        Anyways I went ahead and replaced throttle body gasket, looped throttle body water heater and tightened couple hoses on intake and vacuum increased to 12 from 8 in idle which seems right given I have an aggressive cam.
        It idles much better now as well and clunk has been reduced in on/off throttle.
