Annoying clunk/jerk from driveline.. any help?
  • jasonbk
    • Aug 2011
    • 555
    Hey guys,
    The other day I replaced my diff(rebuilt 4.10 LSD with new diff bushing) and rear subframe mounts.
    The change was very noticeable and the car felt very smooth without any jerk/clunk when changing gears.
    Few weeks later I've replaced both CV axle because I was getting loud chattering noise from the rear end. However old CV axle was in pretty good shape and it turned out the noise was due to break-in period of the LSD.
    Right after I replaced the CV axles, I noticed very slight jerk whenever I load/unload the car. In few weeks jerking got worse quickly and I've changed transmission mount as well. I also rocked my driveshaft to see if there's any play, but it was tight and guibo was in decent shape (although I saw few small rubber bits were chipped off from guibo)
    New transmission mounts helped reducing jerking a lot, but I can still feel a bit of play when I load/unload.
    Another symptom is small thunk noise from rear when I'm putting into 1st and 2nd gear. Even when the engine is off, I can make the noise by shifting into 1st. Not sure if this is related to my issue though.
    So far I've replaced:
    -rear subframe bushings
    -transmission mounts
    -Diff
    -Diff bushings
    -CV axles
    I'm suspecting:
    -Worn out CSB (I can't really see anything from under the car with all the exhaust on)
    -Worn out U-joints
    -Currently the m20 is little out of tune because I'm running 288 cam with chipped 153(91 octane & 7k redline) - needs new chip to accommodate the cam
    -General ignition tune-up (they are about 3 years old)
    -Fuel pump
    Anyone had similar issues? Let me know, thanks!
  • Maddog
    • Dec 2006
    • 116
    If the chattering/thumping noise is occuring good takeoff, it Could be the center bearing. Noise usually dissipate once car is cruising.
    • jasonbk
      • Aug 2011
      • 555
      I can only hear the thump as soon as I shift into a gear (before releasing clutch), and jerking happens only when I push or release the gas pedal.
      • Kershaw
        • 11822
        That sounds like either the center suppor bearing or the rear subframe bushings. Check the csb first. I get it's toast.
        AWD > RWD
        • turbo55
          • Jul 2014
          • 223
          You can get a look (although not a great one) of the CSB with the exhaust and shield on if you use a mirror and flashlight from near the guibo. It's not easy to line the mirror and light up just right but I've done it before.
          • doorman
            • Mar 2015
            • 360
            Check to make sure your CV axles don't have any play in them.
            I have one that has a bit of slop. With the car in gear and on jack stands on can turn the rear wheel a bit and the diff side doesn't move.
            • TobyB
              • 5268
              Are your engine mounts good?
              t
              • jasonbk
                • Aug 2011
                • 555
                I actually put new subframe bushings as well when I got the new LSD. Mirror is great idea though - I'll try it on next weekend.
                I also put new engine mounts about 2 years ago - they still look good.
                • Maddog
                  • Dec 2006
                  • 116
                  As you know, eventually parts wear/fatigue and need to be replaced. E30s are over 25 years of age and any part with rubber should be replaced, including muffler hangers, suspension bushings, brake line, etc.:grin:
                  Ditto on checking the engine mounts. My former 1985 318i (gutless wonder) made the same type of noise at takeoff and worsened over time; initially thought my exhaust system brackets were broken.
                  If your e30 is high mileage, it's good to replace these items.
                  My "newer" 1988 325is has all new bushings front and rear, engine mounts, CSB, guibo, etc.; did this all when I had an engine build.
                  I am having my 1997 M3's CSB and guibo replaced this week when I have the rear wheel bearings replaced. Car has over 180k and replacing them as a preventative measure.
                  • Northern
                    I like cupcakes & sh!tboxes
                    • 5248
                    I get a clunk in reverse, sometimes first if the clutch chatters. Pretty much replaced everything on the car and it hasn't gone away, so I'm going for round two on rear subframe bushings/RTABs
                    Originally posted by priapism
                    Originally posted by shameson
                    • jasonbk
                      • Aug 2011
                      • 555
                      Update - I replaced:
                      New 173 ECU with correct chip from SSSQUID
                      caps, rotors, ignition wires, spark plugs
                      adjusted throttle cable
                      replaced AFM with good working one (old one had loose spring which didn't close the flap all the way)
                      Checked the throttle body and it was clean without any gunk.
                      TPS was working properly (both idle and wot)
                      Since then jerking/clunking is lot better now - but it's still there.
                      Basically below 3k rpm when I release/apply throttle there is a slight jerk. It completely disappears when the car is cold but as car gets warmer it reappears.
                      I still gotta:
                      Test continuity on my TPS and replacement AFM
                      Clean ICV
                      Check all injectors
                      If those don't fix the issue I'm gonna move onto fuel related stuff.
                      • Streichholzschächtelchen
                        • Jan 2009
                        • 1670
                        but csb is good right?
                        Jah bless! :pimp:
                        • jasonbk
                          • Aug 2011
                          • 555
                          Oh yeah, forgot to mention that - when the car was up in the air I could take a peak onto CSB with a tiny mirror and they looked fine. And there was no play whatsoever when I shook the driveshaft on each directions.
                          • DirtyTh3rty
                            • May 2015
                            • 101
                            Mine is bad u-joint as i put the rear wheels off the ground and jolted the shaft back an forwards (turning) and there was play. But my knock happens when say im in first going about 10mph and throw the clutch in it knocks and you feel the jerk a little. If yours is only occurring with the gas pedal then I would check the throttle cable or motor mounts
                            88' BMW 325is - Daily
                            • jasonbk
                              • Aug 2011
                              • 555
                              Here's an update on this.
                              So the bucking and weird jerkiness only happens below 2500 rpm - and vacuum test showed that I have very low vacuum (8-9) below 2500 rpm. As I rev it the pressure becomes normal.
                              I checked rubber hoses to see if there's any sign of vacuum leak but I couldn't find anything - and it's weird that it loses so much vacuum below certain rpm range and regain it.
