Budget stroker time....
  • xLibelle
    • Aug 2004
    • 2673
    #46
    NICE!! you seriously work fast
    • RobertK
      Kicked cancer's ASS.
      • Jun 2005
      • 5864
      #47
      Originally posted by rs4pro3
      She's alive, I couldn't believe how fast the engine started, I bridged the fuel pump relay to build up pressure, and with in just a few cranks it fired right to life. Was running exteremly ruff, but that was becuase I got the 2 lines on my Adjustable FPR hooked up backwards, It was running with 100psi of fuel in the rail for a little bit :crazy: I got those swapped around and it runs nice and smooth with a 700 rpm idle. The coolant system bled with no problems and I drove it around town for about 20 miles getting a feel for the new found power. I absolutely love it, chirps the g-sports in first gear accelerating no problem, and pulls like a train. The engine sounds so dang mean it's not funny, the thing revs like a bat out of hell. I have no idea what duration this cam is, all I was told is it's an aftermarker performance 325i unit. I haven't even hit the revlimiter yet as there just is not the need like the eta would always need to get moving.
      *insert Tim Allen more power grunt here*
      [chant]Dyno! Dyno! Dyno![/chant]
      • rs4pro3
        • 5808
        #48
        this is only the 12th time I've either yanked or reinstalled a bmw engine so it's easy now. I didn't even have to pull out the volt meter, I got the c101 conversion wiring dead on and ever function works:)
        85 325e 2.7 ITB'd stroker
        • RobertK
          • Jun 2005
          • 5864
          #49
          So does this mean you will finally get to come to Knoxville and check out my 92is?
          • rs4pro3
            • 5808
            #50
            Ya possibly on the 20th or the 25th
            • trashcop 80s 80s
              • Jun 2004
              • 1130
              #51
              Nice work, and damn fast too. It would have taken me forever. I'd like to ride in it one day.
              • RobertK
                • Jun 2005
                • 5864
                #52
                Kewl.. ygpm
                • rs4pro3
                  • 5808
                  #53
                  ya basically just 2 days from when I started till it ran
                  it only took about that long when I did the m30 swap but I swapped it into my parts car first and got it running so all i had to do is drop it straight in and turn the key.
                    • 34839
                    #54
                    any chance you'll do a dyno run? I'd love to see how the budget strokers compare. N/A M20s are fun! :)
                    • xLibelle
                      • Aug 2004
                      • 2673
                      #55
                      so this is a low compression 2.7i? (basicly i head on e block?)
                      • rs4pro3
                        • 5808
                        #56
                        here the complete list
                        eta block
                        eta crank
                        eta pistons
                        eta head(ported on intake and exhaust side)
                        Dual I valve springs
                        Aftermarket I cam
                        I intake manifold, TB etc...
                        I exhaust manifolds
                        Full 325i motronic 1.3 setup
                        I only spend about $1200 on it but that included the wideband o2 sensor and some other stuff.
                        I'm going to throw a MAF on it soon once I get a 325i cat on it.
                        I'd like to do a dyno run on it sometime. There aren’t any shops here in town that I know of that have a dyno so I'd probably have to go down to Atlanta.
                        I'm getting ready to help my buddy drop a 323i head on his eta block, so we may both go in at the same time and see how the modified eta head does compared to the 323i head.
                        So far I love the engine, the vibrations at idle are a little obsessive with the urethane mounts but I'll live with it. I think my eta cat is giving to much backpressure, so I'm going to throw and I cat on as soon as I can find one.
                        • rs4pro3
                          • 5808
                          #57
                          Here are some pics of the engine completly back together
                          I need to make a mount for the FPR, and clean up the brake booster vacume lines, but I'll do that all when I throw the MAF on
                          • Sean
                            • 5793
                            #58
                            Damn dude, you did work fast.
                            I just got my Alpina B3 Chip today. I can't wait to put it in and see if it makes an improvement in my car's performance! :)
                            - Sean Hayes
                            • EtaSport
                              • 2853
                              #59
                              How's it running?
                              I got a little more work done on the head, and the cam finally came in. I actually have a junk eta head sitting in the garage as well, so I am going to find out how much you can take out of the top portion of the intake port before going too far. I was able to smooth out the pocket about 1/4 inch above the valve seat, and I read today in car craft that it helps a good bit. The exhaust side can benefit from this too.
                              I found that there is a lot to remove from the exhaust, but I put my gaskets up and noticed that it was a little off-center with the port. I was trying to cut using the old carbon marks as a guide and part of the port got cut off by the gasket. This time im also going to hit the intake and exhaust manifolds just a bit, then decide if im running the shorty headers i picked up.
                              ETA power!!
                              Old and improved:
                              • rs4pro3
                                • 5808
                                #60
                                It's running great. I still need to free up the exhuast a bit, and do the MAF conversion. But having the power to pass without downshifting, doing hard runs with the AC still on, and being able to do 65mph in second gear is nice. I'm thinking of upping the rear end ratio from 3.25 to something not sure yet. Today I helped a friend put a 3.45 on his chipped eta and man does that thing take off. It just runs out of revs fast, where as I can keep going, and going, and going.....
