Machine shop News
  • JeLani
    • Aug 2015
    • 1552
    Machine shop News
    Dropped the 885 off the other day at a local machine shop for a pressure test and Valve job/check. They called me today and my head passed the pressure test , however they told me that my Cylinder 3 valve was not making a good seal. What can I do about this? And how does this affect driveability? And i dont want it back in unless thats taken care of.. But now they just have to resurface it and I'll have it back.
    1986 LTW M52 (First project 2015- )
    1998 e36 328ic/5 -
    Roundie alpina pig cheek’d (1969)
    1967 2002 parts car
    1994 318iS junked.
  • DesertBMW
    • Aug 2011
    • 1037
    That is an easy fix. There is a valve seat cleaning paste, you put it on the valve seat and just spin the valve around to clean the seat and then it will seal perfect.
    • JeLani
      • Aug 2015
      • 1552
      Do they just need to be re-adjusted to make sure?
      1998 e36 328ic/5 -
      1967 2002 parts car
      1994 318iS junked.
      • digger
        • Nov 2005
        • 6147
        if the valve itself is ok, you get the seat recut/reground depending on what equipment the shop has. to do this the guides need to be within spec otherwise you cant cut them properly. you dont use the lapping paste to fix leaky seats...that paste/compound is a final process to check/smooth the contact face. many people advocate not using the paste at all as you can cut a seat or grind it to seal straight off the bat and a tiny bit of the fine grit from the paste can get trapped in the seat leading to lower seat life as its hard to remove 100%
        • JeLani
          • Aug 2015
          • 1552
          to me it looks like they need to be re-adjusted. Cylinder 5 ( i think ) is the one that is stuck open, i'll give a picture of it later but they told me on the invoice that 3 of my exhaust and 3 of my intake valves failed.
          1998 e36 328ic/5 -
          1967 2002 parts car
          1994 318iS junked.
          • JeLani
            • Aug 2015
            • 1552
            1998 e36 328ic/5 -
            1967 2002 parts car
            1994 318iS junked.
            • digger
              • Nov 2005
              • 6147
              what does that show exactly? hopefully you know if the cam and rocker are installed some of the valves will always be open at any point
              • jeffnhiscars
                • Jun 2011
                • 6011
                What exactly does "valve failure" mean ?
                Alice the Time Capsule
                • JeLani
                  • Aug 2015
                  • 1552
                  i assume a valve leak test
                  1998 e36 328ic/5 -
                  1967 2002 parts car
                  1994 318iS junked.
                  • JeLani
                    • Aug 2015
                    • 1552
                    Did not know:(
                    1998 e36 328ic/5 -
                    1967 2002 parts car
                    1994 318iS junked.
                    • digger
                      • Nov 2005
                      • 6147
                      why not get the shop to do a refresh?
                      • JeLani
                        • Aug 2015
                        • 1552
                        If by that you mean a resurface? I did get that done as well as a pressure test that checked out well
                        1998 e36 328ic/5 -
                        1967 2002 parts car
                        1994 318iS junked.
                        • TobyB
                          • 5266
                          No, he means a 'valve job' where they grind the seats and valves to make a nice, spanky seal.
                          Often, on a SOHC bmw, that means guides, too.
                          t
