See page 2 : TDC problems with timing belt change
  • e30onBBSs
    • Dec 2014
    • 1347
    #31
    Originally posted by JeLani
    I hate to say.. Im still stuck. I was told to compensate the camshaft movement for the crank movement. But how to do that precisely? ...
    I guess you could get a torque angle tool and if the crank turns X degrees you would take X/2 and assuming the crank spins clockwise when it turns, you would spin the cam clockwise whatever the sum of X/2 is.
    If it turns counter clockwise idk what you would do because the cam bolt might loosen itself, might not though so it's definitely worth a shot.
    So you would need a protractor to measure the angle from the crank's TDC to wherever it lands. Let's say it's 5 degrees. Then get something like this http://www.thetoolwarehouse.net/otc-...FQ6LaQodnRkFWw
    You put the socket for the cam bolt on the end of the tool, then connect a breaker bar to the other side. Line it up at 0 and then turn it precisely to whatever X/2 is. You stop turning the breaker bar when you hit X/2 while it's in motion. The breaker bar will probably go back a bit. I learned it this way, but it could be wrong. You should probably do some research about what other's think because something this precise is way more important than 1 or 2 deg off a head bolt or whatever.
    Then they should both be in time. Remember that crank spins 2x the cam, and not the other way around!
    Good luck dude! Don't let it get you down, stupid stuff happens to all of us.
    BMW tech
    Umass Amherst
    05 wrx sti
    • JeLani
      • Aug 2015
      • 1552
      #32
      It is stupid , any idea on how this trouble is even caused?
      Sent from my payphone using Tapatalk
      1986 LTW M52 (First project 2015- )
      1998 e36 328ic/5 -
      Roundie alpina pig cheek’d (1969)
      1967 2002 parts car
      1994 318iS junked.
      • e30onBBSs
        • Dec 2014
        • 1347
        #33
        I have no idea. It's definitely possible to accidently spin the crank but having it systematically move the same amount for no apparent reason every time beats me.
        BMW tech
        Umass Amherst
        05 wrx sti
        • JeLani
          • Aug 2015
          • 1552
          #34
          Beats my arse definitely into going 24v , but thats worse case ;) , i'm going to try what you told me above though .. I dont see why that wouldnt work . Thanks for that tup though. You seem to be the only dude lingering around the m20 subforums lmao whats up with that?
          1998 e36 328ic/5 -
          1967 2002 parts car
          1994 318iS junked.
          • Kershaw
            • 11822
            #35
            I wish I had something useful to say. I just can't think of anything to say to help you. I followed the Bentley the first time around I didn't have any of your problems. Since I don't have any experience with your issue, I dunno.
            AWD > RWD
            • e30onBBSs
              • Dec 2014
              • 1347
              #36
              Haha there are others too =) I've asked and still ask questions so I help out when I can!
              BMW tech
              Umass Amherst
              05 wrx sti
              • 2mAn
                Señior Mod
                • 20975
                #37
                This is why a timing belt job is a right of passage :rofl:
                Seriously though, have a friend come over and put a ratchet on the crank to hold it in place while you're putting the belt on.
                Simon
                Current Cars:
                -1966 Blue Boat
                -1969 Red VW
                -1986 White BMW
                -2006 Green Thing
                Make R3V Great Again -2020
                • Kershaw
                  • 11822
                  #38
                  ^ Yeah, maybe another local San Diegan (sp?) can stop by and address your issues.
                  AWD > RWD
                  • JeLani
                    • Aug 2015
                    • 1552
                    #39
                    Size?
                    1998 e36 328ic/5 -
                    1967 2002 parts car
                    1994 318iS junked.
                    • e30onBBSs
                      • Dec 2014
                      • 1347
                      #40
                      This!! ^ Way easier than mine. 22mm
                      BMW tech
                      Umass Amherst
                      05 wrx sti
                      • JeLani
                        • Aug 2015
                        • 1552
                        #41
                        1998 e36 328ic/5 -
                        1967 2002 parts car
                        1994 318iS junked.
                        • e30onBBSs
                          • Dec 2014
                          • 1347
                          #42
                          Post in the regional thread for wherever you live. Tons of cali members on here
                          BMW tech
                          Umass Amherst
                          05 wrx sti
                          • JeLani
                            • Aug 2015
                            • 1552
                            #43
                            bumping an old thread here , but my problem with the timing 'jumping' was because i still had my spark plugs installed, I can see why many members missed that as a reason why it would jump timing because it's it can be kind of the unthinkable to really affect tdc alignment. and I don't know if its because i have a 'high compression' build over a stock m20 2.5 ; being the cause of the crank jump. any who. my m20 is up for grabs.
                            1998 e36 328ic/5 -
                            1967 2002 parts car
                            1994 318iS junked.
