.015 Throttle plate clearance AND Throttle Position Switch
  • tomstin
    • Mar 2015
    • 571
    Been chasing a high idle when warm and been addressing several problems one at a time. Red neck smoke test shows no leaks. The ICV, controller and related sensors seem to be good. The one thing I'm struggling with is the .015 throttle plate clearance. Mine is almost zero. But, if I get the .015 clearance, I can't get the throttle position switch to close.
    Any insight?
    2004 525i Manual - 1985 325E Coupe Manual
  • digger
    • Nov 2005
    • 6194
    isn't the throttle switch slotted for adjustment?
    • jeffnhiscars
      • Jun 2011
      • 6011
      Yes and IIRC the throttle should have .003. The gap is only to insure your tps can close so the icv can manage idle
      Whatever you adjust it to put a continuity tester on the tps and rotate it til it goes to zero then lock it down
      Alice the Time Capsule
      • tomstin
        • Mar 2015
        • 571
        Thanks all! I thought I read that the throttle plate needed .015, mine is probably closer to .003 mentioned above so maybe I'm good.
        The throttle position switch is slotted, I can't seem to get .015 AND the switch at the same time. I can get one or the other, not both.
        I'll continue my search. Very frustrating but I'm not giving up quite yet! Other than this, the car seems to run pretty well. I've been beating back one problem at a time. Fully expected most of this when I bought the car, was looking for a project...and I have one!
        Add in someone in the car's previous life buggered the head of the throttle stop screw which is an entirely different saga.
        • jeffnhiscars
          • Jun 2011
          • 6011
          Leave the feeler gauge in the throttle body while you adjust the tps.
