If it's over 80 degrees outside, my ETA won't start
  • RoyalW/BlauCheese
    • Dec 2015
    • 126
    Update for anyone that cares: put in a new cps and start up was rough but it gradually seems to be getting better. Gotta wait for a hot day to know if the problem remains
    _____________________________________________
    1987 325
    • Best_name_available
      • Jul 2014
      • 479
      Glad to hear that was the no start culprit, you should try cleaning out your icv with a shit ton of carb cleaner and maybe do a seafoam treatment, clear the m20's throat
      Originally posted by Vokuhila
      I laughed, and then I serioused
      • RoyalW/BlauCheese
        • Dec 2015
        • 126
        It was a hot one yesterday and guess what! It had the same symptoms and wouldn't start. After driving for a bit when ever i would let it idle it would stay at 1500 rpm. Then after I turned the car off it wouldn't start back up.
        I have an eBay chip in it. Could that be the problem?
        1987 325
        • RoyalW/BlauCheese
          • Dec 2015
          • 126
          It will crank forever, it just won't start...
          1987 325
          • Cephas
            • Apr 2012
            • 878
            How did that happen to the sensor? Wow.
            What did/does the other one look like? (You have two in the bell housing).
            • 2mAn
              Señior Mod
              • 20729
              doesnt the sensor in the transmission cause all kinds of problems?
              Simon
              Current Cars:
              -1966 Lotus Elan
              -1986 German Car
              -2006 Volkswagen Jetta TDI
              Make R3V Great Again -2020
              • cunninglinguist
                • Mar 2004
                • 281
                Wouldn't be surprised if it was your ICV/ICM. If it has failed/closed in the wrong position it can prevent the car from starting. To test this, you could temporarily replace the ICV with a section of tubing with a penny with a small hole drilled in it (aka the "penny trick").
                • RoyalW/BlauCheese
                  • Dec 2015
                  • 126
                  Looks like spark was melting it
                  1987 325
                  • RoyalW/BlauCheese
                    • Dec 2015
                    • 126
                    There are two sensors. I tried the cps and I got the other one so I'll try switching those and see what happens.
                    1987 325
                    • RoyalW/BlauCheese
                      • Dec 2015
                      • 126
                      I'll try the test thx! My next buy is an icv anyway cause mine has always been a little jankey.
                      1987 325
                      • cunninglinguist
                        • Mar 2004
                        • 281
                        Also note that a bad ICV can cause excessive current draw and damage your ICM, so you might have to replace or repair that as well.
                        • RoyalW/BlauCheese
                          • Dec 2015
                          • 126
                          Going to install ICV. In the meantime I took out my eBay chip and it helped a little. I have to wait for a hot day to make sure
                          1987 325
                          • RoyalW/BlauCheese
                            • Dec 2015
                            • 126
                            Quick update. Changed the icv and no difference. The no start stopped after I took out the ebay chip. Want to do a smoke test but I need to find someone in the Santa Barbara area with one.
                            1987 325
