m30 afm to stock m20, does it work???
  • german g
    • Feb 2006
    • 1608
    the m20 never fails to impress me with its durability..
    90is, longtube headers/straight pipe/mark d 18# 93 0ctane chip/18# injectors/vogtland springs/bilst. sports
    :firehop:
    • JoeMadoo
      • 936
      Mine had 225k when i blew the head gasket.
      So for the 027 M30 AFMs, do you still need to swap the internals?
      '86 E30
      '05 E53 X5
      '72 Firebird
      '10 Prius
      '03 Tundra
      • 92 mtechnic cabrio
        • 4907
        No, that's why they are so popular, they are plug and play.
        R.I.P 07/01/09 - 04/23/10 :(
        • Super Eurobeat
          • 147
          my 88 528e super eta has 391,XXX miles stock
          • ZinRot325i
            • 291
            Is that auto or manny trans?
            If Auto...kudos.
            :wgaf:
            • 87-325ic
              • Apr 2006
              • 1198
              so the 027 are completely plug and play?
              all those people of swapping in the m20 electronics are doing so b.c they could not get an "027" m30 afm?
              also, with the 027, will we get any of those 1222 engine codes and problems associated with the AFM swap?
              thanks a lot.
              this is what we want?
              • digger
                • Nov 2005
                • 6144
                the 027 gives the same output voltage as the M20 one i.e ~4.9-4.95V when flap is fully open and around 0.3-0.4 when fully closed. This leads me to believe that the voltage vs flap angle is the same.The difference is that at the same flap opening/angle the M30 would be flowing more air (it is bigger opening and the spring tension may be different) so the critical voltage vs airflow is different so while it is plug and play the tuning will be off (lean). So the use of 19lbs is though to compensate for this but i who knows whether it is too much or too little it may vary depending whether the AFM spring has been molested. If you have a method to adjust the fuel pressure or a pigggback etc it should allow you to achieve reasonable results and no adjsuting things so it doesn't smell like fuel anymore is not a good method to detect that the AFR is ok.
