To chip or not to chip? That is the question...
  • mr.
    • Jun 2013
    • 513
    Hello R3V, Newbie here
    Looking to get some insight on a few questions I had.
    Later this year I'll be doing some maintenance on my M20 (timing belt, thermostat, etc.) While I'm in there, I figured I might as well do some freshening up and throw in a new 02 Sensor, rebuilt AFM by BavRest, and rebuilt stock 14lb injectors by CATuned. Going to be picking up a KAMotors CAI with a headlight duct and a better flowing exhaust (most likely an Ireland Engineering one). Aside from that, my engine will remain completely stock (for now).
    I've been debating picking up a MarkD 91 Octane chip for 14lb injectors, my question is; would I feel any benefits in running a chip with the setup I listed above? Or should I just go ahead and opt for rebuilt 17 or 19lb injectors with Mark's Chip, also throw in a rebuilt M30 AFM.
    My apologies in advance if I come across as ignorant or as a newb. Not the most informed in the engine department. But I figured this is what R3V is for.
    Again, thanks in advance!
  • digger
    • Nov 2005
    • 6198
    91 chip MD or squid, 14.5lb inj and call it a day
    • mr.
      • Jun 2013
      • 513
      Originally posted by digger
      91 chip MD or squid, 14lb inj and call it a day
      Leaning towards a SSSQUID but those require 17lb injectors I believe
      • Kershaw
        • 11822
        That's probably a typo, stock are 14lbs, so I'm sure he meant 17lb injectors.
        AWD > RWD
        • mr.
          • Jun 2013
          • 513
          Gotcha, figured. Will probably end up doing rebuilt M50 17lb injectors and a SQUID Chip
          Sent from my SM-G530T1 using Tapatalk
          • digger
            • Nov 2005
            • 6198
            There is a 14.5lb option that's what stock are rated at afaik
            • jeffnhiscars
              • Jun 2011
              • 6011
              Jesse (SSSquid) will match your chip to whichever injectors you use and I believe his website lets you spec that. He told me the stock chip will manage 17s although we installed 19s and a chip when we met up and he street tuned my car.
              It doesn't get any better for service and support
              Alice the Time Capsule
              • mr.
                • Jun 2013
                • 513
                Awesome, thanks for sharing. I'll give him an email about it and see what would work best.
                Still deciding between 14lb or 17lb, would the M20 really benefit from the added fuel with an "off the shelf tune"
                • digger
                  • Nov 2005
                  • 6198
                  no, plus M50 injectors arent 17lb at the 3b youre going to run in an E30. they are 17lb at something like 3.5b
                  • Vincent Brick
                    • Feb 2013
                    • 879
                    Is it true that a chip and injectors is only good for ~5whp max over stock?
                    My apologies for hijacking the newb thread with a related newb question. :)
                    1991 325i Sport - Calypsorot Metallic - DAILY DRIVEN
                    WTB in SoCal: 8"/10" Lukebox, leather Sport steering wheel, 60L MotoMeter fuel gauge, Thule/Yakima roof rack
                    • digger
                      • Nov 2005
                      • 6198
                      No that's not true, you dont gain huge amount peak to peak numbers on bone stock but with mods you can do a lot better than that with chip and tune
                      • mr.
                        • Jun 2013
                        • 513
                        And in my case, the only mods being; intake, and exhaust. The chip of course too
                        • Vincent Brick
                          • Feb 2013
                          • 879
                          I'm just trying to get a little more power from my M20 and stay California legal, but without spending $1500+ on a head, cam, etc.. The few experienced E30 guys and EMS tuners I know told me not to bother with a chip, that its 5whp and not worth anyones's time. I'm just really disappointed with the M20's performance and by the lack of bolt-on stuff I can do to this car, to the point I am considering moving on very soon. I want something considerably quicker.
                          Again, not trying to hijack, but I think we are on a very similar, though probably previously-discussed search for current info.
                          • mr.
                            • Jun 2013
                            • 513
                            No worries, but you're right. Seems you can't get too much out of this motor without going forced induction. I don't mind the power, it's my daily so I think the power is adequate. Just wanted to liven it up a bit and get it to breathe better.
                            Good luck with your build however, your car is your daily?
                            • digger
                              • Nov 2005
                              • 6198
                              the reality is that looking at the peak to peak whp number is pretty meaningless when making an assessment for a chip there is alot more to how it drives than a single number. You aren't going to come close to the gains possible on the modern turbo engines from a simple tune
