RHD lightweight flywheel
  • mazzo
    • Jul 2014
    • 264
    Any one has experience running one of these? Pros and cons compare to machine the OEM single mass flywheel?
    Do we need to use e21 / euro 323 throw bearing if we use this on a E30 325i engine?
    Thanks!
    Current:
    '88 325ic Silver 5sp
    '17 Subaru Outback 3.6R
    Past:
    '14 Rav4 EV (with tons of torque!)
    '06 325i Black 5sp
    '02 S4 Avant Black 6sp
    '00 Boxster Silver 5sp
    '98 New Bettle Yellow 5sp
  • digger
    • Nov 2005
    • 6215
    pros would be less inertia so engine will accelerate quicker. the benefit will be felt most in lower gears since the gain is proportional to how fast the engine's revs change.
    ive not used or experienced this particular FW but have experienced others that weren't as light.
    • jeffnhiscars
      • Jun 2011
      • 6011
      I emailed that question last week to RHD and was told it used a standard b25 TOB. Shipping is about $50 and they don't take long in transit (say a week).
      I did have a JBR aluminum flywheel in my M10 and it def revs quicker but also slows down sooner since you don't have the momentum. I plan to buy that one from RHD for the swap I'm about to do on my Cabrio
      Alice the Time Capsule
      • Reichart12
        • Aug 2012
        • 2168
        I have one. I like it. You get used to the feel pretty quick so drivability is no problem. My transmission is older so in neutral with clutch out you can hear a little rattle if youre listening for it. Its a sporty drive but I have other mods done so its hard to pinpoint which is giving me the most feel.
        I had to use the 323i TOB only because my transmission is from the E engine set up (stock flywheel is dual mass) but as mentioned if you have the 325i you will use the standard TOB. And yes, shipping was quick considering it came from another country.
        Instagram: Reichart12
        • jeffnhiscars
          • Jun 2011
          • 6011
          So a 5spd from an ETA mated to this flywheel in a b25 requires the 323 TOB ?
          • Reichart12
            • Aug 2012
            • 2168
            For me it did. The transmission housing is slightly longer (so I was told) because of the thicker dual mass flywheel. The 323 TOB is slightly longer than the 325i TOB. Using the single mass or RHD flywheel required the 323 to make up the difference. I also needed to buy new bolts for the flywheel since the dual mass ones were ~52mm and the single mass ones were ~28mm.
            • jeffnhiscars
              • Jun 2011
              • 6011
              I think it's recommended to change flywheel bolts anyway. Were you able to order a clutch kit for,a 323 or did you just buy the parts separately ?
              • Reichart12
                • Aug 2012
                • 2168
                I bought a 325i kit from autohausaz for pretty cheap and then the 323 TOB from another site with another order I had going. Still all cheaper than buying everything separate. You may be able to buy a 323 kit, I don't think I ever looked.
                • jeffnhiscars
                  • Jun 2011
                  • 6011
                  Sounds about how I do my major parts shopping. Thanks again for pointing out the TOB spec. If I had found out the hard way I'd have invented some new swear phrases (I don't use mere swear words) !!
                  • iwantspeed
                    • 3164
                    I have this flywheel and really like it.
                    Make sure to upgrade to a brass pivot point instead of the stock plastic
                    Project
                    Parts for Sale
                    Feedback
                    YouTube Channel
                    • digger
                      • Nov 2005
                      • 6215
                      any downsides to the brass one besides slight price difference?
                      • iwantspeed
                        • 3164
                        No.
                        My plastic one was broken and quite challenging to remove the Knub.
                        The brass part wears in nicely into the harder steel material.
                        You don't want 2 similar metals rubbing metal on metal.
                        Project
                        Parts for Sale
                        Feedback
                        YouTube Channel
                        • iwantspeed
                          • 3164
                          trans jack coming in handy
                          pressure plate and clutch disc removed
                          made a custom tool to remove the flywheel bolts
                          i rented a tool from my local pepboys
                          slide hammer and pilot bearing puller
                          it was way to big to fit inside of the bearing
                          i found a rod to fit inside to keep the jaw from popping out and it worked
                          tool configuration
                          new flywheel ready to go on.
                          new pilot bearing installed
                          new flywheel going on.
                          locking tool in place
                          clutch disc installed
                          thanks to mike for letting me borrow the clutch alignment tool.(buttjuice)
                          pressure plate installed
                          plastic pivot pin was broken
                          bell housing cleaned up and brass pivot pin installed
                          old flywheel weight 20 lbs new flywheel 7 lbs.
                          winning
                          Project
                          Parts for Sale
                          Feedback
                          YouTube Channel
                          • mazzo
                            • Jul 2014
                            • 264
                            Cool, thanks for all the info :)
                            Current:
                            Past:
                            '06 325i Black 5sp
                            • jeffnhiscars
                              • Jun 2011
                              • 6011
                              :yawn:C
                              Do you have a PN for the 323 TOB you ordered ? I just ordered the flywheel and will get a standard b25 clutch kit but am thing to order the extra TOB just in case.
