Doods, my compression seems funky
  • traxamilli
    • Nov 2012
    • 82
    Front of Car
    #151 psi
    #151 psi
    #152 psi
    #152 psi
    #151 psi
    #175 psi - spark plug looks brand new, possibly not firing
    Back of Car
    anyone have any input on what would cause 1 cylinder to read high? I just put new rings in the block, motor is a 2.7i
  • flyboyx
    • 8371
    i don't know what an eta engine should read but those numbers seem pretty low in general. i assume the last one in your list above is #1?
    you don't have near enough info there for us to help you out.
    Gigitty Gigitty!!!!
    • Dj Buttchug
      • Jun 2010
      • 7677
      back of the car would be #6. Op when you re ringed the engine did you put the rings in dry?
      Turbo M42 Build Thread :Here
      Ig:ryno_pzk
      I like the tuna here.
      Originally posted by lambo
      • cagedbunny
        • Nov 2008
        • 515
        Did you kill the fuel (remove pump relay/unplug injectors?) Easy way to skew the readings after the first cylinder you test otherwise.
        • flyboyx
          • 8371
          has it been driven a bit so they will seat?
          Gigitty Gigitty!!!!
          • TobyB
            • 5256
            #6 is hogging all the nitrous...
            t
