Installed m50 injectors having minor issue need chip or something else
  • Kevinl
    • Oct 2012
    • 897
    So i replaced the injectors in the e30 with rebuilt m50 ones from mepeh the car runs better than the whole time i have owned it there are however a couple things i have noticed one thing i noticed is when letting off the throttle the revs seem to slowly fall where as before they would decrease rapidly
    The other issue is between 4-6k you can feel the engine rev harder at a certain point like the car is not reving as fast as it should then it all of sudden feels to pickup and rev normal
    Replaced spark plugs with ngk when i did injectors as well
    I kind of think it needs the chip the ecu is trying to adapt but this is a 25+ year old fuel injection system that has a limited amount of what it can do
    1989 BMW 325is Lachsilber metallic 5 speed
    2007 BMW 335i KARMESINROT 6 Speed manual
    2011 BMW X5 35I
  • packratbimmer
    • Dec 2009
    • 1335
    Not sure if this will help, but I have M50 injectors and a stock set-up. After changing my FPR and oxygen sensor, the car runs way better.
    I think a chip tuned for the M50 injectors is my next move.
    • imjusthere
      • Jul 2014
      • 119
      I have the same problem. I just installed green tops and it doesn't run as well as I'd hoped. I'm considering going with a war chip and tune. Subscribing now to learn your solution.
      Sent from my XT1254 using Tapatalk
      • digger
        • Nov 2005
        • 6194
        the engine should still run "fine" with slightly bigger injectors with zero mods. i have run 18lb on bone stock and its perfectly able to cope evn though it is far from ideal. i would think there are also other issues at play
        • whitebulat22
          • Apr 2014
          • 330
          I agree there's other issues. My 2.7i instantly ran perfectly on stock 153 tune on M50 injectors and never misfired a single time. However, the reason I did the conversion is because I thought I had electronic gremlins, which turned out to just be my new NGK plugs. My eta had absolutely no power all of a sudden when it warmed up and sounded like a Subaru boxer. I later put them in my buddies eta and it did the exact same thing.
          The ecu can handle the injectors nicely, I think you should try your old spark plugs.
          • Kevinl
            • Oct 2012
            • 897
            I might have thrown them away but they were autolites so they were cheap maybe ill buy another set
            I was going to get bosch plugs but i guess they were no longer made
            The car ran fine until an injector failed so the plugs were put in at the same time and could be the issue
            2011 BMW X5 35I
