M20 with m50 tps noise issue
  • CrazyPrime
    • Jun 2014
    • 286
    I have a turbo m20 and it has the variable TPS off a m50 it has a adapter plate and is plugged into the stock m20 TPS plug. Would having it plugged into the stock plug work? when I took my car to the dyno he couldn't get it to idle good because the TPS had noise and the idle was hunting. I have the m50 pigtail and I can wire it into the harness but my question is. Is the stock pigtail wired correctly for the m50 TPS? or does it need rewired with the m50 TPS? is there any other reasons why the TPS would have noise?
  • digger
    • Nov 2005
    • 6194
    Wired incorrectly or low battery voltage can cause noise. Is the sensor good? I don't remember if the m50 sensor is plug and play in stock harness you may need to switch a few pins.
    • Northern
      I like cupcakes & sh!tboxes
      • 5283
      Common practice (at least, with the M5x TPS while running MS) is to switch pin 1&2 at the TPS connector if you encounter noise, IIRC they're BRN/BLK and BRN/ORG
      Originally posted by priapism
      Originally posted by shameson
      • CrazyPrime
        • Jun 2014
        • 286
        Alright thanks guys I will switch those 2 and see what it does.
        Sent from my E6653 using Tapatalk
