M20 Porting Question
  • redlightpete
    • Mar 2012
    • 265
    I know the general guideline is to not blindly attempt to port an 885 head, but I still have to ask. On the head I'm working on, on the short side of the ports, there's a corner where machined section meets the casting, and another where the seat meets the port. Would it be useful to round off these edges, or am I more likely to make things worse?
  • TobyB
    • 5265
    If you simply radius them, you won't hurt anything. But you probably won't gain 10 bhp, either-
    That's what the red paint on the valve cover is for.
    t
    • SkiFree
      • Jun 2011
      • 2766
      Historically speaking, rounding off that edge is a nice touch. As Toby says, it's no red valve cover, but it's not a bad thing either.
      ADAMS Autosport
      • E30DriftMissile
        • Aug 2012
        • 301
        Don't mean to thread Jack but if you deck the head does that effect tdc and cam timing?
        Edited*
        • SkiFree
          • Jun 2011
          • 2766
          Clarify what "tac timing" is and we might be able to help.
          Cam timing: Yes
          ADAMS Autosport
          • E30DriftMissile
            • Aug 2012
            • 301
            I decked my head and lightly shaved the block and at tdc I was really hard to turn the crank so I backed off
            • digger
              • Nov 2005
              • 6147
              if the cam axis and crank axis change then yes the cam timing moves a bit. how much was it decked?
