Help with cam removal
  • Jimmyac28
    • Jul 2016
    • 371
    What else can I do to get the cam off?
    • Jimmyac28
      • Jul 2016
      • 371
      I poured some oil to lubricate the bearings overnight to see if that helps
      • e30sh
        • Apr 2015
        • 618
        Screw the cam sprocket bolt back in and ViceGrip it. Tap and turn and see if that gets u anywhere.
        • digger
          • Nov 2005
          • 6072
          heat it up a bit in an oven
          • wilholl
            • May 2012
            • 518
            Are you trying to pull it out the front or push it out the back?
            1988 325 non-letter Seta "Bronzit"
            1991 325ic "Laguna Green" (Sold)
            1993 325i "Laguna Green/Silver" (Sold)
            1998 528i "Artic Silver" m-sport(totalled by drunk driver)
            2000 528i Titansilber/gray m-sport
            2000 528i Titansilber/black m-sport(sold)
            2001 525i Anthracite m-sport(sold)
            2013 750i Black/Black m-sport "Beast"
            • Jimmyac28
              • Jul 2016
              • 371
              Pull it out the front but it wont budge
              • Jimmyac28
                • Jul 2016
                • 371
                Do you think that will work?
                • TehRaydarlover
                  • Mar 2013
                  • 544
                  Cam lobes look fine, I don't think it lost oil pressure. Does the cam turn easily? I'm guessing the head is very warped. If the cam doesn't slide in, out, and turn nicely you probably don't want to use the head. Use an oven like said above, or a torch to grow the head, should come right out.
                  Build Thread
                  Rear Diff Rebuild
                  Rebuildable Viscous Coupling
                  Transfer Case Rebuild
                  "Life is simpler with 12 valves"
                  • Jimmyac28
                    • Jul 2016
                    • 371
                    The cam doesnt turn by hand but it does turn with a wrend with a little resistance
                    • ThatOneEuroE30
                      • Dec 2013
                      • 8626
                      At this point id be throwing head in trash and buying a used one. If head is warped enough it wont let cam come out. Then the head and cam are both useless and your just wasting time.
                      1991 318i 4dr slick top
                      Mtech 2 turbo restoration
                      • digger
                        • Nov 2005
                        • 6072
                        if it doesnt take too much torque to turn there might be a burr thats getting caught
                        • E30DriftMissile
                          • Aug 2012
                          • 301
                          Yea I agree. I doubt it's warped to the point the cam won't come out. If it spins have someone rotate it slowly while you mallet/wooden dowel from the back. Mine wasn't easy to come out either. Head was fine it was just stuck with about 220k on it. I got mine out by just not giving a fuck anymore and "strategically" using a pvc pipe wedged on one of the lobes and hammered the shit out of it. 2 wacks and it came out. So far I'm 10k on that head still strong.
                          • Jimmyac28
                            • Jul 2016
                            • 371
                            I took off the plug on the back of the head and used a dowel and a hammer to hit the cam from there. It came loose after a couple of hits. The cam bearings look good but I might have messed up the rear cam bearing on the head when I was taking off the cap on the back
                            • jeffnhiscars
                              • Jun 2011
                              • 6010
                              Unless you gouged the hell out of the bearing just smooth it up with some fine wet/dry
                              Alice the Time Capsule
                              • PKile
                                • Apr 2016
                                • 184
                                I would not use either the head or the cam after these symptoms. At the very least the head is toast and the cam should be carefully checked with a couple V-blocks and a dial indicator for straightness.
