Help with cam removal
  • Jimmyac28
    • Jul 2016
    • 371
    I have an 885 head with bent valves and 2 broken rockers from a snapped timing belt. I'm trying to take the head apart, I took the rockers off and now trying to take off the cam that from what ive read it should just slide out but the cam wont even move. I'm I missing something here?
  • jeffnhiscars
    • Jun 2011
    • 6011
    Did you unbolt the cam seal housing ?
    Alice the Time Capsule
    • Jimmyac28
      • Jul 2016
      • 371
      Yes but the cam still wont slide out
      • redlightpete
        • Mar 2012
        • 265
        Did the rocker shafts slide out easily? Can you get the cam to rotate? Is the head warped or cracked?
        • Jimmyac28
          • Jul 2016
          • 371
          The rocker shafts came out pretty easy, no sure if the head is warped, cant see any cracks.
          • TobyB
            • 5287
            t
            • Jimmyac28
              • Jul 2016
              • 371
              Originally posted by TobyB
              t
              Yes, I can turn it using the can sprocket bolt and a wrench. Im I missing something or could it be a warped head?
              • digger
                • Nov 2005
                • 6194
                take a photo of the disassembled head you have in front of you
                • Jimmyac28
                  • Jul 2016
                  • 371
                  I have a photo but I says upload error everytime I try to upload it
                  • jeffnhiscars
                    • Jun 2011
                    • 6011
                    Cam rotates, rockers slid out...you need to remove the cam seal housing. Someone may have bonded it to the head
                    • Jimmyac28
                      • Jul 2016
                      • 371
                      here are the pictures
                      • Jimmyac28
                        • Jul 2016
                        • 371
                        Cam seal housing is off
                        • e30sh
                          • Apr 2015
                          • 618
                          If the rockers are out of the way/ cam seal housing removed, the only thing I can think of is a low/ no oil pressure issue chewed up the cam bearings. I bought a head one time that looked perfect until the cam cam out.
                          Since the rocker shafts came out easy, it' shouldn't be too warped.
                          Good luck.
                          • jeffnhiscars
                            • Jun 2011
                            • 6011
                            Have you tried carefully "persuading" it with a wood dowel and a hammer ?
                            • Jimmyac28
                              • Jul 2016
                              • 371
                              Yes I did, but its no moving
