Need your help -- WTF is this part?!?!
  • jllphan
    • Nov 2011
    • 115
    Alright guys (and gal), trying to track down an intake leak and think I've found it. The elbow connector. The one that connects the hose that comes off the ICV and goes in to the throttle body. It's very loose on my car and was able to find it by spraying carb cleaner in the area. Is this part available by itself? Spent two hours searching realoem, pelican parts, ECS, FCPeuro and BavAuto w/ no luck.
    "A BMW that needs nothing, has an owner that's not paying attention."
    • 37833
    Just silicone or JB Weld it in place. Problem solved. :)
    Grover Beach, California
    BimmerHeads.com
    • kway
      • 1084
      I always just cement them back in place with 2 part epoxy (jb weld or similar)
      Edit: ^ beat me to it!
      '84 318i - Lapisblau/Schwarz (in cryosleep)
      '06 330i - Titansilber/Schwarz
      • TobyB
        • 5288
        It's called
        'that damned elbow that always loosens up because it's just pressed in there'
        and the official repair is
        t
        • bangn
          • Sep 2011
          • 760
          comes with a throttle body!
          Boris - 89 E30 325i
          84- E30 323i
          • ewolfe57
            • Jun 2016
            • 29
            ...but for real though is there any way to buy one of those short of a whole new throttle body? I'm in a similar boat except that my little elbow guy is missing in action.
            • jeffnhiscars
              • Jun 2011
              • 6011
              There's a DIY to tap the throttle body and use AN fittings. That tap is on my list...and mine don't leak
              Alice the Time Capsule
              • jllphan
                • Nov 2011
                • 115
                Yeah, ok. Was thinking I'd JB Weld it as a last resort, just trying not to slap another bandaid on this ole gal. Tap and AN is interesting, i might look into that.
                • digger
                  • Nov 2005
                  • 6195
                  silicone it in, that way you can easily remove later if needed
                  • wilholl
                    • May 2012
                    • 518
                    ^^+1^^
                    1988 325 non-letter Seta "Bronzit"
                    1991 325ic "Laguna Green" (Sold)
                    1993 325i "Laguna Green/Silver" (Sold)
                    1998 528i "Artic Silver" m-sport(totalled by drunk driver)
                    2000 528i Titansilber/gray m-sport
                    2000 528i Titansilber/black m-sport(sold)
                    2001 525i Anthracite m-sport(sold)
                    2013 750i Black/Black m-sport "Beast"
                    • bangn
                      • Sep 2011
                      • 760
                      are you fucking blind to everyones posts?
                      Boris - 89 E30 325i
                      84- E30 323i
                      • jeffnhiscars
                        • Jun 2011
                        • 6011
                        Why would you ever want to remove it if it's threaded and never leaks
                        • mrsleeve
                          • Mar 2005
                          • 16387
                          This is the correct way to fix things like this. I would tap it but thats me (as I have a couple of sets of Tap/dies and odds and ends fittings bucket laying around already) It does not have to be a AN fitting, could prolly just use a brass NPT to Barb 90* just as easily form the hardware store. Or if you cant find that a NPT to NPT 90* fitting with a NPT to barb nipple threaded on to the end of that.......
                          That said; the epoxy way is just as effective, cheaper (unless you have a correct tap already), easier to source the materials, and likely faster (if you use a fast cure epoxy) and more or less an idiot proof repair method.....
                          Originally posted by Fusion
                          William Pitt-
                          • portland-e30
                            • Jul 2016
                            • 26
                            I've been using wood glue to seal mine
