m20b27 stutter at WOT
  • Syncro325is
    • 574
    Customer asked me to swap a running motor into his 86 325e due to some sort of prior engine failure. He gave me the car not running and half apart unfortunately. Swapped new engine in and I now have a running issue where the car will idle high and will sputter to the point of no power at WOT with no load. I can pull the temp sensor and it will run all the way up to WOT with no sputter which seems to have the most effect on the running issue. I have checked resistance on the sensor and replaced it with a new one of similar resistance change. I have checked continuity between the wiring and the ICM as well as ECU. I have grounded everything.
    I have found multiple threads where people have seemed to have this same issue but the only solution I have found was using a potentiometer in place of the temp sensor to fool it into at least running, but still a little rich.
    It may also be helpful to know that when the sensor is plugged in I can clog the intake with my hand and get the car to run somewhat normal.
    I have smoke tested and eliminated any leaks.
    Any helpful suggestions for the temp sensor issue?
  • Kershaw
    • 11822
    Have you checked the CPS?
    Unplugged the o2 sensor?
    AWD > RWD
    • Syncro325is
      • 574
      Yes, Unplugged the o2 and it made no difference. Crank sensor in trans seems to be ok. It shuts off completely when the running ref sensor is unplugged. I did not find a chance to check resistance on the sensor yet
      • TobyB
        • 5287
        AFM?
        t
        • Kershaw
          • 11822
          I would check the resistance, but I wouldn't even trust it if it reads 5500 -/+ 10%. I've seen way out of spec CPSs work just fine and ones that spec out ok be the issue.
          AWD > RWD
          • Syncro325is
            • 574
            Haha gotta love pre obd2. Alrighty I believe I have a new sensor on the way anyway
            • jeffnhiscars
              • Jun 2011
              • 6011
              Have you checked the tps for continuity at idle and wot ?
              Alice the Time Capsule
              • TobyB
                • 5287
                ...and fuel pressure?...
                t
                • Syncro325is
                  • 574
                  Tps has been tested, and yes works perfectly. Fuel pressure is steady at 36 until it stutters at which point it is at 40 lbs.
