ETA pistons
  • packratbimmer
    • Dec 2009
    • 1334
    ETA pistons
    How many stock compression ratios were there on the non-superETA 2.7 ETA cars? ...and, is it a piston height change or a shape change?
    Thanks
  • estoguy
    • May 2013
    • 1087
    The regular Eta engine compression is 9.0:1. The only difference was in the SuperEtas, they were 8.5:1.
    Estoguy
    • digger
      • Nov 2005
      • 6119
      also euro engines also had 10.2:1 and 11:1 different shape (sjhallower dish or raised dome)
      • ak-
        • 12422
        [img]http://i.imgur.com/Fc68b0w.jpg[/img
        Awesome pic.
        What's the significance of piston ring depth (MT) when comparing the SETA to the first listed B25? What's it matter?
        1991 325iS turbo
        • digger
          • Nov 2005
          • 6119
          MT is supposed to be the depth of depression (dish depth) its normally used to adjust compression. it looks like seta has lower dome and shallower dish.
          • ak-
            • 12422
            Well that was easy to figure out - not sure why I read 'ring' instead of 'top'.
            My wrongly read concern was going to lead to the question whether SETA rings differ from B25 rings and if so, how? Can't find good info online.
            1991 325iS turbo
            • digger
              • Nov 2005
              • 6119
              piston rings? iirc the regular eta are different axial width to b25 . as for seta idk someone out there with a piston lying around might help you out and post some numbers.
              b25 is 1.50/1.75/3.0
              b27 might be 1.50/2.00/4.00 but thats off top of my head
              based on real OEM the ring p/n between seta and eta are the same
              • ak-
                • 12422
                Okay thank you.
                Considering that, would you say one is superior in controlling oil during have vacuum / deceleration?
                1991 325iS turbo
                • digger
                  • Nov 2005
                  • 6119
                  doubt youd notice a difference
                  • packratbimmer
                    • Dec 2009
                    • 1334
                    Damn! Thanks guys.
                    I read that the early eta block was a little taller as well.
                    Anyone ever confirm that?
                    THX
                    • digger
                      • Nov 2005
                      • 6119
                      old eta blocks are not taller from what ive measured
                      • packratbimmer
                        • Dec 2009
                        • 1334
                        Good to know - I was a little skeptical about that.
                        Thanks again!
                        • ForcedFirebird
                          • Feb 2007
                          • 8300
                          Pretty sure the seta uses eta rings, made that mistake once when ordering (not sure if they all did, but just measure twice, order once lol). From memory, the rings were thinner on the (s)eta, with less tension to curb friction (just like the cams with less bearings, and softer valve springs).
                          I have not seen any blocks with varying heights, but then again, I have only seen one block come in the shop that had that weird large freeze plug in the back.
                          The seta and "i" pistons are noticeably different when next to each other, the valve reliefs give away the compression difference from the top, pin height from the side.
                          Also, Digger mentioned the compression differences, but remember the seta uses the 885 head and risen/angled squish band (like the b25), the eta used the 200 head and flat squish band.
                          john@m20guru.com
                          Links:
                          • ForcedFirebird
                            • Feb 2007
                            • 8300
                            john@m20guru.com
                            Links:
