Nuke Cam Pulley Clearance Problem
  • redlightpete
    • Mar 2012
    • 266
    Anyone else have problems with the Nuke adjustable cam pulley hitting the two screws on the cam seal housing? I ended up scraping some material off the back of the pulley at the bosses for the threaded holes.
  • digger
    • Nov 2005
    • 6207
    Yeah you gotta countersink the cam seal retainer plate and add some countersink screws
    • redlightpete
      • Mar 2012
      • 266
      Thanks, Digger. I ended up chamfering off the pulley. Pretty annoying on a component that is marketed for this specific application.
      The diameter fit between the outer and inner parts is looser than I expected. Did you do anything special to keep the outer section true to the inner?
      • digger
        • Nov 2005
        • 6207
        I don't remember there being any significant play
        Another thing to check is that the cam has a big enough chamfer to clear the pulley hub internal radius
