Help Identifying E30 ECU?
  • zytoun395
    • May 2016
    • 17
    Hey guys!
    So im trying to upgrade my computer and do an MAF swap. I pulled out my ECU but there is no sticker on the case identifying it???
    I was looking to buy a 173 with a WAR chip and the MAF off of a friend, but i just was make sure the ecu will be easily compatible.
    IMG_2282 by Oliver Issa
    IMG_2281 by Oliver Issa
    thanks for the help!!!!
  • reelizmpro
    • 9553
    Looks like someone removed the Bosch sticker for whatever reason. Does it have 3 rows of pins? If so, the 173 is compatible. Looks like you have a Motronic 1.3 already.
    88 M3 - LACHSSILBER
    89 M3 - ALPINEWEISS II
    • agent
      Vice Grand Pubaa
      • 7960
      Yep, 173 ECU will work in any "i" car.
      If the ECU is original, it's in a 1988 iX automatic sedan.
      Originally posted by kronus
      • ForcedFirebird
        • Feb 2007
        • 8300
        Looks like a refurb. A 173 chip will work in all the single PCB cases (Bosch Motronic 1.3). The earlier ECU's have dual PCB's and need to use a 153 chip - the eta ECU's are also a league of their own - except the 1988 325(e), aka super ETA which used a 173 variant.
        john@m20guru.com
        Links:
        • zytoun395
          • May 2016
          • 17
          how did you know that just from the ecu?
          • ForcedFirebird
            • Feb 2007
            • 8300
            VIN number is on the sticker. Last 7 shows what car it came from...
            http://www.realoem.com/bmw/enUS/select?vin=8135098
            and a google search of the vin shows it sold on eBay...
            http://www.ebay.com/itm/BMW-3-Series-/291725701128
            john@m20guru.com
            Links:
            • zytoun395
              • May 2016
              • 17
              didnt realize the vin was on the sticker
