Will this blow my motor?
  • Idrisu
    • Jul 2015
    • 173
    Does anyone know where the hole on the bottom right leads to? I dropped a screw and it fell inside.
  • Idrisu
    • Jul 2015
    • 173
    My guess is the oil pan?
    • Rontgen
      • May 2016
      • 137
      Yes, that's an oil drain back hole that leads through the block and into the oil pan. As to whether the bolt made it all the way through or not...you'll have to pull the pan and see.
      You could get a flexible borescope with a light and have a look down the hole to see? Amazon has USB models for cheap.
      - Darrell
      2001 BMW M5
      1990 BMW 325is - Build Thread
      • ForcedFirebird
        • Feb 2007
        • 8300
        Yup, straight to the oil pan.
        john@m20guru.com
        Links:
        • nrubenstein
          • 3148
          Drop the pan.
          If it's not in there, push a hangar wire through.
          Edit: It might also be possible to get it out via the drain hole with a magnet or just the force of oil flow.
          2002 BMW M3 Alpinweiß/Black
          1999 323i GTS2 Alpinweiß
          1995 M3 Dakargelb/Black
          - S50B32/S6S420G/3.91
          1990 325is Brilliantrot/Tan
          1989 M3 Alpinweiß/Black
          • ELVA164
            • 4861
            About 30 seconds at redline (when cold) should provide enough oil pressure to get almost anything out of there.
            • TobyB
              • 5287
              You'll be fine.
              t
              • reelizmpro
                • 9554
                If it's that small, with a little luck you may be able to get it with a telescopic magnet through the drain plug hole.
                88 M3 - LACHSSILBER
                89 M3 - ALPINEWEISS II
                • mr2peak
                  • 2388
                  Most Likely Yes.
                  Get it out.
                  Drive it hard. Maintain it well.
                  A Topless Memorandum
                  • TobyB
                    • 5287
                    Once it's out of danger of getting bound up in the valve train, there's nothing for it to hurt-
                    you'll be fine.
                    If it didn't get hung up on a ledge of head gasket, it probably made it to the pan-
                    where it will fall to the bottom, and pretty much just sit there.
                    The oil pump has a screen, so it can't get sucked in there. The crank's 2+ inches
                    up, so it'll NEVER hit that, and there's not even any timing chain to make you nervous.
                    Put a magnet on your drain plug next oil change, ad maybe it'll make its way there.
                    But I bet it just sits on the bottom of the pan for the rest of the life of the motor...
                    No worries.
                    t
