Clogged fuel return line
  • parkerbink
    • Jun 2004
    • 10138
    After a slew of repairs to get my '92 cabrio running (and it is) I am down to a clogged return line.
    The shop that got it this far wanted to replace the tank which I will do if I have to.
    Does anyone have a solution to clear the line?
  • e30davie
    • Apr 2016
    • 1788
    Air compressor:)
    • parkerbink
      • Jun 2004
      • 10138
      They soaked it overnight with fuel system cleaner and blew the line unsuccessfully.
      • e30davie
        • Apr 2016
        • 1788
        I wonder how a fuel return line even gets clogged? was the car sitting for an extended period of time? is it full of rust?
        If it is rust it might be worth replacing it....
        • parkerbink
          • Jun 2004
          • 10138
          Searching finds it to be common. I just got the car, unsure on it's sitting. I do know the PO had a fuel pump die on the freeway, starve the engine of fuel, blow a few valves (his story) he rebuilt the head replaced the timing belt, replaced the pump did a bunch of pm while you are in there etc and the car ran. Then it died and he was done.
          I have replaced the CPS, ICV, MAF, FPR, injectors, plugs, coil fuel pump relay and ANOTHER fuel pump, both temp sensors, thermostat and I am sure more before taking it to the shop who replaced the throttle body and diagnosed the return being clogged.
          He was unwilling to rod the line out which was a solution I found on Bimmerforums he was concerned about explosions.
          • parkerbink
            • Jun 2004
            • 10138
            This morning I opened the pump access panel and blew my compressor into the rubber hose connected to the hardline on top of the tank (I assume that is the return) I heard the gas "bubble" and did it a few times.
            The shop said the motor would be starved for fuel after a few minutes. I let it idle for 10, then drove it for 5. It revs freely and seems fine.
            About an hour ago I drove it around the block for 10 minutes, then went to the gas station and filled the tank all told 20 minutes plus of driving/engine running. It runs fine (although it still has the damn temp sensor CEL)
            Should I consider it ok?
            • cscracker
              • Jan 2017
              • 131
              Correct me if I'm wrong, but I wouldn't expect a clogged return line to cause fuel starvation. I'd expect it to cause extra load on the fuel pump and high fuel pressure.
              • parkerbink
                • Jun 2004
                • 10138
                He said it had high pressure and would eventually run out of gas. I ordered a gauge and will replace the tank if I have to.
                • Kershaw
                  • 11822
                  I mean... eventually all cars run out of gas. Higher pressure would mean more fuel going through your injectors than the DME expects, so your car would run rich.
                  Put a white piece of paper behind your exhaust while idling. Does it get speckled in black? If it does you're running rich.
                  AWD > RWD
                  • parkerbink
                    • Jun 2004
                    • 10138
                    Thanks for the idea, on start up nothing, clean white envelope. After it warmed I put packing paper around the exhaust with enough to still be in front when revving pushed it away and nothing. No gas spitting out.
                    It had a horrible hard start and rough idle issue, resolved by a new throttle body. I am thinking it needed another day soaking on the carb cleaner so was not clear before I towed it home.
                    I ordered a fuel pressure gauge and am not driving it until I am sure it is ok.
                    • ThomEM
                      • Jun 2026
                      • 1
                      I had the exact same problem, indicated by the idling rail pressure measured at 70 psi / 4.7 bar, a month ago. I've been tossing in fuel additive each tank since then. When I finally realized that the return line had to be blocked, I opened it up and managed to put half a bottle of O'Reilly's Injector Cleanser into the hose, gradually over perhaps 10 minutes. It was accepting of some flow, which seemed promising. The next day my own pressure gauge arrived and I measured normal pressures of 2.5 bar idling, 3.0 bar when opening the throttle or when pulling off the vacuum line actuating the pressure regulator. Crucially, by pinching the return line, the pressure jumped to 5 bar, proving that the regulator was working with an open line.
                      I conclude that the obstruction was no loose and sedimentary but rather was hardened gum or varnish settled out of the gasoline while the car was in storage for 20 years.
                      So don't give up on solvents to cure the problem.
