30,000 mile service
  • mjposner
    • Aug 2015
    • 169
    30,000 mile service
    I am about to hit 30,000 miles. Should I have the valves adjusted?
  • mjposner
    • Aug 2015
    • 169
    I will need a new timing belt on age next year, can the valve adjustment wait or should I just do everything early?
    Belt and water pump were replaced 12/28/12 at 26,371 miles
    • estoguy
      • May 2013
      • 1087
      Honestly, if the TB was last done in 2012, I'd be replacing it. Technically, a valve adjustment wouldn't be a "while you're in there" job, but if you're already doing the belt, adding in that job isn't a big deal.
      Service interval for valve clearance by the book is 15,000 miles.
      Estoguy
      • Das Delfin
        • Sep 2014
        • 2293
        valves have a 10k mile adjustment interval. It is easy enough to learn to DIY and all you have to buy is a new valve cover gasket and rocker plugs (4 of them)
        tb is 4 years/60k miles, whichever comes first. Definitely not something you want to risk on your numbers matching 30k mile car.
        • mjposner
          • Aug 2015
          • 169
          Okay so timing belt to be done? What about water pump? Keep?
          • dnguyen1963
            • Nov 2011
            • 2651
            If you are going to do the TB, replace the water pump too.
            • digger
              • Nov 2005
              • 6207
              OE waterpump will do two TB changes, aftermarket ones i would do at the same time
              • jeffnhiscars
                • Jun 2011
                • 6011
                While the TB is a mileage OR time swap, that doesn't apply to the water pump. Agreed it's every other belt ASSUMING you go full mileage or close to it on the TB (so 100k or so). If you've put only 4K on the car sincemit was replaced, its still virtually new and I'd leave it.
                Alice the Time Capsule
                • Das Delfin
                  • Sep 2014
                  • 2293
                  ^ unless it's a stock water pump with one of those plastic impellers
                  • mjposner
                    • Aug 2015
                    • 169
                    Its states RFMD Water Pump FP Number 11 51 9 070 759 so it is an oem part (installed by a BMW Dealer)
                    I believe based on online searches it is a metal impeller.
                    • dnguyen1963
                      • Nov 2011
                      • 2651
                      The impeller is important, but more important is the bearing. The cost for a water pump is only about $40. Just replace the thing when you do the TB.
                      • mjposner
                        • Aug 2015
                        • 169
                        I use or time the biggest issue with the water pump. It only has 4k miles
                        • digger
                          • Nov 2005
                          • 6207
                          use, they wont deteriorate with age like rubber or plastics. i always use metal impeller pumps
                          • nrubenstein
                            • 3148
                            Water pump failure is highly variable. The big issue issue is that if it fails, you basically have to do another timing belt job. (It's possible but difficult to replace the water pump without replacing the TB, but it takes two people and is unpleasant.)
                            And since you have to remove the radiator to get enough clearance to do the TB job, there's very, very little added cost as you're already draining the coolant anyway. So do the pump. They are dirt cheap.
                            2002 BMW M3 Alpinweiß/Black
                            1999 323i GTS2 Alpinweiß
                            1995 M3 Dakargelb/Black
                            - S50B32/S6S420G/3.91
                            1990 325is Brilliantrot/Tan
                            1989 M3 Alpinweiß/Black
                            • zaq123
                              • Jul 2016
                              • 1570
                              or redo the entire head. I had WP fail on my TDI (GRAFF unit, just seized up one day while on the road), shaved a few teeth on TB and pistons met valves. It sucked.
