ETA No Warm Start
  • jeffnhiscars
    • Jun 2011
    • 6011
    ETA No Warm Start
    Alice stared acting up recently. Mornings she starts and runs flawlessly. Once at OT a quick stop doesn't seem to matter, but after a 20-30 mi use cool down she absolutely refuses to start. Sounds like she almost catches...wants to...but won't.
    I do think she's flooding so I disabled the cold start valve, since it shouldn't fire when the engine is warm.
    I'd have said points if she had any and since it's clearly temp related my research points to the CTS. I took a series's of resistance readings as she cooled down and the changes seemed linear. Notwithstanding, I threw in a new CTS which made no difference.
    So stone cold and quick stops fom OT...perfect..modest stops and a total no start.
    Thoughts ?
    Alice the Time Capsule
  • dnguyen1963
    • Nov 2011
    • 2651
    Try this...after 20-30 min cool down, disconnect the negative cable from the battery. Let the car sit for another 10 min, re-connect the cable, and try to start the car. If the car starts then I suspect that the DME is not quite normal.
    • jeffnhiscars
      • Jun 2011
      • 6011
      It does have a chip so who knows. Next time it won't start we will try that. Thanks for the suggestion
      • squidmaster
        • Aug 2011
        • 2666
        Hmm I've had similar issues when there is excessive oil blow-by when the plugs get coated with oil and it hinders their firing. The heat of the engine sometimes promotes increased blow-by. However, it would usually start after cranking it for a little.
        Best way to check is to recreate the initial conditions (drive it for a little), then before turning it on again, pull a few plugs and check for any oil or residue on them.
        Another possibility is a bad o2 or injector that has given incorrect warm-start enrichment.
        If this issue happened recently, and the car has been chipped for a while, I would doubt it would have to do with the chip itself. Were there any other recent changes to the car?
        • jeffnhiscars
          • Jun 2011
          • 6011
          No changes at all other than oil and filter.
          • e30sh
            • Apr 2015
            • 618
            Next time it wont start, Pull the vacuum hose from the FPR to intake. Squirt a little starting fluid into the intake. This will let you know if it's fuel or spark.
            • jeffnhiscars
              • Jun 2011
              • 6011
              Let me amend my "no changes" comments. We did run out of gas recently and did replace the trans oil cooler hoses.
              I don't see how eithe of those would cause a temp related issue
              • jeffnhiscars
                • Jun 2011
                • 6011
                After taking her for a run to full OT I let her sit until she wouldn't start. Disconnected the ground and left her for a while and then she started right up. ive never seen an ecu reset "cure" a no start but this sure points a finger at the potential source.
                Will see how she behaves moving forward
                Follow up...after another 20 min it started but just barely so I'm ruling out the ecu at least for now. My theory is that it is one or more leaky injectors. Stone cold it starts cause there's no residual fuel pressure. After 20-30 hot minutes it will start cause enough fuel hasn't leaked out to cause a problem in a warm engine. Any longer and it's too flooded to start until all the residual fuel pressure has bled down and the excess fuel has evaporated off.
                I'll check the plugs next time it doesn't start and report back and get a fuel pressure gauge to track the pressure
                • squidmaster
                  • Aug 2011
                  • 2666
                  Could also be a bad FPR-- perhaps the vacuum line has been blocked or clogged or stuck in some way
                  • digger
                    • Nov 2005
                    • 6215
                    I had a similar issue just changed injectors and it went away. Don't know what specifically was wrong with them as apparently they weren't leaking ( had them checked). I borrowed a used set from another car ford falcon to diagnose the issue then bought a new set
                    • jeffnhiscars
                      • Jun 2011
                      • 6011
                      I would think that would effect running all the time and can't imagine why it would only effect warm restarts and not hot or cold.
                      I am inclined to think it's injectors but since I'm on the verge of doing the 731 head and motronic upgrade I'm not sure if it's worth tracking down a set of eta injectors (or any other eta specific parts). I may however, just do the motronic swap to see if that fixes it, before I pull the head. I'll have to think on this
                      • e30sh
                        • Apr 2015
                        • 618
                        Did you give starting fluid a shot?
                        • jeffnhiscars
                          • Jun 2011
                          • 6011
                          I don't keep ether on hand and there are other checks to do before I get any. My thoughts being that if ether makes it start I have a no/low fuel problem. If it doesn't start I either have no spark or too much fuel. Removing the plugs to check for fouling and spark should pretty much tell me the same thing. I'm also going to check fuel pressure next.
                          • squidmaster
                            • Aug 2011
                            • 2666
                            The e30 fpr adjusts fuel pressure with manifold vacuum. If the diaphragm is damaged or hindered, it could lead to the loss of fuel pressure you described. While running the O2 may be able to correct fueling just enough for it to work, but on startup the lack of pressure probably just can't compensate, or it's tossing way too much fuel in. just an idea from an issue I've seen before
                            Sent from my Robin using Tapatalk
                            • jeffnhiscars
                              • Jun 2011
                              • 6011
                              What could cause the fpr to perform well when hot or cold and not when warm ? I will check fuel pressure but am having trouble seeing how these symptoms can be tied to vacuum.
                              Remember this is not a constant problem which rules out or limits a number of potential causes.
