new head gasket
  • low808
    • Nov 2013
    • 661
    new head gasket
    Installing new head gasket and noticed my timing was off after torquing the head bolts. Pulled the head off and found oil on the head gasket. Am I able to reuse the head gasket or do I need a new one.
  • zaq123
    • Jul 2016
    • 1559
    need a new one
      If the head was fully torqued, you will need a new head gasket and new head bolts as they are torque to yield and one time use.
      • digger
        • Nov 2005
        • 6176
        the plot thickens.
        • zaq123
          • Jul 2016
          • 1559
          wait....this wasn't your original question...you just said that there is a little bit oil on your HG, asking if it's ok to use.
          Now you are saying it was installed already? Obviously no, not ok to RE use.
          • jeffnhiscars
            • Jun 2011
            • 6011
            Im wondering why he removed the head after seeing his timing was off rather than just adjusting the belt (assuming he hadnt run the car)
            Alice the Time Capsule
            • low808
              • Nov 2013
              • 661
              Yeas it wasnt. I cleaned if off and installed it. Then notince I didn't set the timming correctly since I was working on it at night. The next day I pulled it off. Thanks for all the answers. I ordered a new head gasket
