Cold Start Issue: Wont hold idle after ~30sec SOLVED
  • 2mAn
    Señior Mod
    • 21085
    Hey all, bought my 325i a few weeks ago and its been good overall, but Ive been having a cold start issue.
    Symptoms: At initial start-up it fires up immediately and purrs at ~700rpms. No bouncing or hunting at all. Then it will just die. It will have some trouble starting after this, but eventually when the car is warm the issue goes away. My temp solution was to hold the "idle" at ~1500rpms initially, then 2500-3000rpms more recently to speed up the time to get it to operating temp. Also, if it tries to die, sometimes I can power through it. This seemed to be work while I tried to chip away at it, but today it got the best of me and now Im asking for R3Vs help...
    What Ive done so far: When it first happened I did some searching and asking around and the consensus was to change the Coolant Temp Sensors. I ordered both the one for the cluster (Brown) and the DME (Blue) since they were cheap and a 5 minute job to change. I got them through Blunt and we decided of the many options to use a Bosch sensor for the DME. This seemed to slightly change the "attitude" of the issue. Prior to the change it would be a softer stumble and ultimate death. After it seemed like it was a stronger death and I couldnt recover it. This is where I increased the rpms from ~1500 -> ~2500 and I could basically warm the car up faster and I had a better chance at fighting off the death.
    Today, it wasnt cooperating at all. The car was parked for 3 days while I was gone for the long weekend. Same story, it fired up immediately, I held idle at 2500 then after ~30seconds: death. typically it comes back to life soon after a few tries. Today it didnt want to, and even when it would finally come to life, it would almost immediately die and there was nothing I could do to save it. I wasnt able to warm up the car and eventually threw in the towel and took the Roadster to work.
    My guess I strongly feel this is fuel related. The starter looks new and she cranks over hard and consistently. All the ignition related parts look new too, but the fuel injectors look old and are dirty. I was planning on doing the 4-pintle Mustang injector + Sssquid Chip soon, and Im tempted to do this ASAP, but I also dont want to throw parts at it and hide the true problem.
    So where should I start?
    Simon
    Current Cars:
    -1966 Blue Boat
    -1969 Red VW
    -1986 White BMW
    -2006 Green Thing
    Make R3V Great Again -2020
  • ThatOneEuroE30
    • Dec 2013
    • 8626
    If it was me personally I'd start with replacing fuel filter since its cheap enough and testing the fuel pump to make sure its pushing the correct amount of fuel. Id also check the regulator. It does definitely sound like a fueling issue.
    1991 318i 4dr slick top
    Mtech 2 turbo restoration
    • jeffnhiscars
      • Jun 2011
      • 6011
      There has been a rash of these types of issues lately (including on our ETA) and in many cases its the CPS so that has become my goto suggestion.
      Alice the Time Capsule
      • 2mAn
        Señior Mod
        • 21085
        Yea the Fuel Filter and fuel lines are good maintenance parts and wouldnt be a waste, but I doubt this will fix the problem.
        Really?... a Crank Position Sensor? never thought of that one.
        Are there any other sensors I should look at replacing?
        Simon
        Current Cars:
        -1966 Blue Boat
        -1969 Red VW
        -1986 White BMW
        -2006 Green Thing
        • 2mAn
          Señior Mod
          • 21085
          Bump
          Went home and it fired up in the afternoon and didnt give me much of a headache and drove fine to work today. It still had the hiccup, but I was able to power past it. She didnt die and got up to temp. It seems to be an occasional serious issue, but its an issue nonetheless, so I want to get it done sooner than later. Its only going to get colder from here, so Im assuming this will only get harder until its fixed
          Simon
          Current Cars:
          -1966 Blue Boat
          -1969 Red VW
          -1986 White BMW
          -2006 Green Thing
          • Tinkerer007
            • Mar 2013
            • 252
            I had an issue with my car where it would die at idle (when warm).
            I was thinking I was getting it going with starter fluid, but my mechanic swapped the sensors on the bell housing (one for tach, and one for spark timing) and haven't had the issue since.
            Can you verify if your issue is fuel, or spark?
            (I thought I was getting spark, but that was still the issue.)
            • M-technik-3
              • 18946
              You have an Eta, i's don't have these but the E30 M3 does. Older system, i's use the reference sensor on the front of the crank vs the flywheel sensors.
              • 2mAn
                Señior Mod
                • 21085
                Im going to change the CPS and also the fuel filter. I dont think either of these will solve the problem, but they are good items to replace on a car thats just about 30 years old. I will check to see if they CPS looks bad.
                Im really thinking I should change the injectors too, but I want to work my way to them
                Simon
                Current Cars:
                -1966 Blue Boat
                -1969 Red VW
                -1986 White BMW
                -2006 Green Thing
                • sert57
                  • May 2014
                  • 170
                  Does it seem to run rich or lean when it starts initially?
                  Don't know how relevant, but on my 2.9 i had an issue with the ford injectors leaking. It made cold starts fine, but warm starts were tricky. It even died on me twice on the road.
                  May be relevant, but with this problem im leaning towards not.
                  Icv?
                  • Bimmer_Baron
                    • Sep 2017
                    • 104
                    I would definitely clean your ICV if I were you, I had a similar problem with my ETA. It would fire up and idle fine at first, but instead of just straight up dying, the idle would surge like crazy for a few seconds and then die. I also have a set of freshly rebuilt 19lb injectors if you're interested.
                    Injectors - services, upgrades, rebuild kits and stock sets available! 14.5lb, 17lb, 19lb, 21lb, 28lb, 33lb, M20B27 injectors available https://www.r3vlimited.com/board/sho...d.php?t=413372
                    • 2mAn
                      Señior Mod
                      • 21085
                      Excellent first post Sir! haha I really should clean the ICV to eliminate that as an issue, as Im sure it needs a cleaning anyways.
                      Simon
                      Current Cars:
                      -1966 Blue Boat
                      -1969 Red VW
                      -1986 White BMW
                      -2006 Green Thing
                      • Gregolas
                        • Jun 2011
                        • 1187
                        Smoke test to see if there are any vac leaks??
                        - Greg
                        α Team Founding Member
                        1984 BMW 325 Henna Rot - Sarah -Uber project
                        2011 BMW 335d LeMans Blau - Daily Diesel Torque monster
                        • 2mAn
                          Señior Mod
                          • 21085
                          I could do that, but I think a vac leaks would be a different issue. Wont hurt to do it though. Cleaned the ICV and it seemed like it was already clean. This car keeps showing that its been well maintained. Went to change the airfilter while the ICV was drying and the filter looked new and wasnt dirty at all. The inside of the AFM also looked squeaky clean
                          Weird thing is that since I removed the aftermarket alarm, it doesnt seem like this is a problem anymore. However, that being said and tomorrow being monday, I fully expect my week to start with some stress haha I will keep battling this until its gone.
                          Keep the random ideas coming.
                          Simon
                          Current Cars:
                          -1966 Blue Boat
                          -1969 Red VW
                          -1986 White BMW
                          -2006 Green Thing
                          • 2mAn
                            Señior Mod
                            • 21085
                            Knew I was wrong...
                            Monday = no problem
                            Tuesday = small hiccup, but not really an issue
                            Wednesday = a real bitch until I got it going and held it at ~3k rpms until it was warm...
                            I need to figure this thing out.
                            Simon
                            Current Cars:
                            -1966 Blue Boat
                            -1969 Red VW
                            -1986 White BMW
                            -2006 Green Thing
                            • sert57
                              • May 2014
                              • 170
                              So its basic, but have you checked the engine ground cable? I could see it giving some of the described symptoms.
