M20 rattle at 4k
  • itsonlygeorge
    • Feb 2014
    • 852
    M20 rattle at 4k
    I am not exactly sure what is causing this issue. I have recently adjusted the valves to spec and it didn't make a difference.
    Also recently replaced oil pressure switch as the old one started intermittently lighting up. I saw oil flow at all the rockers while doing the valve adjustment. I used a switch to fire the starter for the adjustment.
    Had similar symptoms to this thread:
    1987 325e Lachssilber w/ MarkD chip and late bumpers, Zender EVO spoiler, s3.25 LSD
    Originally posted by nando
    I don't think there's really strong evidence that ZDDP harms cats.
  • varg
    Florida Turbo Man
    • May 2014
    • 3413
    Fan? If the motor moves under acceleration it could be hitting the shroud/radiator, made worse by the fan flexing at higher rpm. Had that happen with my M42 fan.
    IG @turbovarg
    '91 318is, M20 turbo
    • itsonlygeorge
      • Feb 2014
      • 852
      Ill take a look. I will check engine mounts as well. I changed the clutch and oil pan gasket in June, maybe theres some play in them.
      • itsonlygeorge
        • Feb 2014
        • 852
        I checked the engine mounts and they are tight, no evidence of the fan hitting the radiator.
        like it's a metallic rattle coming from behind the cluster. Not sure what could be causing it. If it was valve related it would be noticeable reving at idle?
