Car starts smoking up the second I hit the freeway?
  • E30_Narek
    • Sep 2014
    • 398
    Hey, everyone. I'm pretty sure I've asked this question before but I still can't find an answer. I've taken it to two mechanics and they can't seem to pinpoint it either. So my problem is that the car starts smoking whenever I hit freeway speeds. It smokes from under the car, not the exhaust. If I pull over, the smoke will start rising from the sides of the car. The smoke is from burning oil. The car does leak minimally from the oil pan gasket and the valve cover. But when I took the car up on a lift, there's oil all over the catalytic convert, all over the transmission, and some has even reached the diff. The diff itself isn't leaking, the oil on the diff is engine oil not gear oil. What I'm thinking is the car is leaking from somewhere and running along the undercarriage of the car and since it hits the exhaust, it's burning off. But where could it leak from that it'll run alongside the bottom of the car? All help is appreciated as I'm trying to avoid driving the car since it's losing a lot of oil and it's pretty embarrassing to drive on the freeway with all the smoke bellowing form underneath it.
  • TobyB
    • 5265
    How's your crankcase vent?
    t
    • barbierij
      • Sep 2012
      • 1294
      Is this an automatic? My 1990 iX would start leaking tranny fluid when I reached around 70MPH
      FS NY: two Audiobahn A235HC amps and audiobahn 1farad capacitor
      Saab/GM tech2 programming
      My for sale thread
      1990 325iX for sale or part out
      Did you buy something from me? Please leave feedback!
      Originally posted by K20RI_211
      And I have to ask if you make a hobby out of thread-bombing with retarded questions?
      • zaq123
        • Jul 2016
        • 1524
        t
        + rear main seal, oil pan gasket, transmission output/input seals etc
        • E30_Narek
          • Sep 2014
          • 398
          Nah it's a stick.
          • E30_Narek
            • Sep 2014
            • 398
            I know my oil pan gasket is leaking. I was thinking if I hit the freeway and it leaks, the winds would kinda push the oil onto the exhaust. That's why my exhaust has a black spot on it which I'm assuming is where the oil hits and burns off.
            • MrBurgundy
              R3V Degenerate
              • Mar 2012
              • 5563
              Where is the burn spot? is the valve cover leaking?
              • E30_Narek
                • Sep 2014
                • 398
                No the valve cover isn't leaking. The burn spot is right where the exhaust bends to run under the car. So basically after the headers and right before the cat.
                • iwantspeed
                  • 3164
                  Try transmission vent pipe
                  Project
                  Parts for Sale
                  Feedback
                  YouTube Channel
