Replacing Blue temp sensor
  • mazzo
    • Jul 2014
    • 264
    Hi all,
    The fuel rail and the bar the hold the fuel pressure regulator block me from using deep socket 19mm at that spot. I tried using angled wrench but the space is very limited (I can barely made 1/4 turn). This is after I already removed the brown temp gauge sensor + hose to radiator. What tools / way do you guys use to gain access and remove that blue sensor?
    Current:
    '88 325ic Silver 5sp
    '17 Subaru Outback 3.6R
    Past:
    '14 Rav4 EV (with tons of torque!)
    '06 325i Black 5sp
    '02 S4 Avant Black 6sp
    '00 Boxster Silver 5sp
    '98 New Bettle Yellow 5sp
  • mazzo
    • Jul 2014
    • 264
    No one? Or people simply replace it during thermostat housing replacement?
    Current:
    Past:
    '06 325i Black 5sp
    • gath
      • 577
      The time I did it I used a deep socket and it worked fine.
      • RobDog
        • Aug 2012
        • 188
        I always use a crowfoot 3/4in or 19mm wrench and it works just fine for me. You just have to remove the brown temp sensor, no need to remove the radiator hose. Once broke free you should be able to turn it by hand. A quarter turn is all your going to get in that tight of spacing. Sounds like you should get it out or on the right path to getting it out. Good luck!
        • digger
          • Nov 2005
          • 6119
          I think I used a lawn mower wrench
          • Kershaw
            • 11822
            Yeah I think this is what I have done too. Deep socket, extension, and 3/8ths impact.
            AWD > RWD
            • e30davie
              • Apr 2016
              • 1788
              You also dont need to swing on it to tighten it up. Make sure the copper washer is in good condition. Preferably new but as long as its not scratched to shit it will be fine.
              • mazzo
                • Jul 2014
                • 264
                Then either my deep socket is too tall and thick, or previous owner install something non standard, because my deep socket just cannot fit into that space...It will hit the rail right below the intake manifold...
                Current:
                Past:
                '06 325i Black 5sp
                • mazzo
                  • Jul 2014
                  • 264
                  Here is the picture: https://www.dropbox.com/s/kfnquyn57e...01436.jpg?dl=0
                  Current:
                  Past:
                  '06 325i Black 5sp
                  • e30davie
                    • Apr 2016
                    • 1788
                    Yep it's tight. I might have used a spanner last time. I do remember trying bascially every tool I own before somethhng worked
                    • MrBurgundy
                      R3V Degenerate
                      • Mar 2012
                      • 5541
                      I've only ever used a wrench.
                      Try taking the brown one out and then the blue one, both with a wrench.
                      IIRC, I'd hit it with a wrench and it should be able to loosen by hand after a quarter or half turn.
