Random CEL when I hit large bumps - SOLVED!
  • 2mAn
    Señior Mod
    • 21040
    Hey Everyone.
    As seems to typically be the case when you are working your way to a solid reliable M20, its two steps forward, one step back (sometimes the reverse too!)
    The car is once again amazing since the 5 speed conversion, but a new issue has popped up. I dont believe them to be related, but I think my more "spirited" driving has revealed the new weakness.
    Here in LA, for whatever reason there are areas on the road that seem to be the equivalent of speed bumps for E30s and a few times Ive driven over these at the speed limit, the CEL will illuminate for a second and then turn off.
    My buddy who swapped the manual over mentioned that the injector harness connector was pretty bad, but he covered it in di electric grease. Im guessing that I need to get back in there and really clean it out, especially because its on the harness side, not the injector harness itself.
    Anything else this could point to? I will finally have some free time to work on my cars again. Im hoping to finish up my Datsun in the next few days so I can get a few more things done on the E30 that Ive been wanting to get done. The list shrinks but theres always new things that pop up
    Thanks in advance
    Simon
    *****UPDATE*******
    Problem solved...
    Thanks for everyones help, it was the connector just like everyone mentioned. Im sure the CPS was a good move still
    Simon
    Current Cars:
    -1966 Blue Boat
    -1969 Red VW
    -1986 White BMW
    -2006 Green Thing
    Make R3V Great Again -2020
  • MrBurgundy
    R3V Degenerate
    • Mar 2012
    • 5604
    Does the car buck or hesitate in any way when this happens?
    • 2mAn
      Señior Mod
      • 21040
      for just the split second that its shaking from the bump
      edit: Now that I think about it, my CPS also was bad and he put a good, used one in
      Simon
      Current Cars:
      -1966 Blue Boat
      -1969 Red VW
      -1986 White BMW
      -2006 Green Thing
      • MrBurgundy
        R3V Degenerate
        • Mar 2012
        • 5604
        I was dealing with a similar problem, but my car would buck really badly when the CEL came one.
        It ended up being the CPS. The routing for the wiring was incorrect, so when I would hit a bump, the engine would yank on the wiring and cause it to lose connection.
        Hopefully you'll find it quickly, because these kinds of problems are usually a PITA
        • 2mAn
          Señior Mod
          • 21040
          I think I should just buy a new CPS, but I dont know which one to get. Is this one of those "Buy OEM or you'll regret it" situations? If not, whats a good one thats worth it.
          Pelican says BMW is NLA
          https://www.pelicanparts.com/catalog...pg3.htm#item12
          Bluntech only has VEMO (?)
          Simon
          Current Cars:
          -1966 Blue Boat
          -1969 Red VW
          -1986 White BMW
          -2006 Green Thing
          • MrBurgundy
            R3V Degenerate
            • Mar 2012
            • 5604
            I’m running a vemo.
            It’s been almost two years and I haven’t had a problem.
            My catalogues only list that one, so I didn’t have any other options
            • 2mAn
              Señior Mod
              • 21040
              Ok thanks, I will check out the harness and look into the CPS
              Simon
              Current Cars:
              -1966 Blue Boat
              -1969 Red VW
              -1986 White BMW
              -2006 Green Thing
              • MrBurgundy
                R3V Degenerate
                • Mar 2012
                • 5604
                Look at your tach when it happens and see if you notice anything obvious.
                • 2mAn
                  Señior Mod
                  • 21040
                  Well... now the CEL is always on. I figured ok let me spend my Saturday night changing the CPS.
                  Old ones looked bad
                  New one from ECS tuning arrived quick
                  Figured this would be quick and easy... but I always get nervous with these feelings because....
                  It didn’t change anything.
                  It sounds like it’s running on 5 cylinders though. Ian suggested a stomp test so I’m about to go do that.
                  Stomp test
                  1-2-5-1
                  I guess it’s back to the injector harness again
                  Simon
                  Current Cars:
                  -1966 Blue Boat
                  -1969 Red VW
                  -1986 White BMW
                  -2006 Green Thing
                  • vtechnik
                    • Jan 2018
                    • 379
                    let me know if you need any pigtails or injector wiring from my eta
                    1988 ~ Lacey ~ 325iS
                    • 2mAn
                      Señior Mod
                      • 21040
                      So we cleaned up the harness and it was pretty dirty but it didn’t make any change. So while it was running I pulled each spark plug wiring to see if there was any change and 2,4,6 showed no change...
                      Ideas?
                      Simon
                      Current Cars:
                      -1966 Blue Boat
                      -1969 Red VW
                      -1986 White BMW
                      -2006 Green Thing
                      • 36brua
                        • 689
                        If the X20 connector was /is corroded only cleaning that pins may not be enough
                        The corrosion can extend into both of the harnesses causing poor connections pull back the rubber boots and have a look
                        You may need to replace some wire and repin
                        My CA legal M60 swap
                        The happening in our garage
                        • IceWhite
                          • Jan 2015
                          • 945
                          Ideas?
                          This is a clue.
                          I hope this helps. C191
                          1990 325i
                          2004 330i Individual 6-speed
                          • 2mAn
                            Señior Mod
                            • 21040
                            Originally posted by IceWhite
                            This is a clue.
                            Definitely does. Its about what I expected. And what a surprise that the one thats giving me issues is the one right smack dab in the middle.
                            Whats the ideal fix here? I dont want to eliminate the connector
                            Simon
                            Current Cars:
                            -1966 Blue Boat
                            -1969 Red VW
                            -1986 White BMW
                            -2006 Green Thing
                            • ForcedFirebird
                              • Feb 2007
                              • 8300
                              Pretty sure I suggested that in a recent PM.
                              The c191 uses the same pins as c101. If you get a pin release tool, you can easily re-pin the connector provided the plastic case is on ok shape. Most of the time I see them with some sort of aftermarket connector. This connector have been a problem spot for s few years now. :/
                              john@m20guru.com
                              Links:
