Random CEL when I hit large bumps - SOLVED!
  • 2mAn
    Señior Mod
    • 21010
    Originally posted by ForcedFirebird
    Pretty sure I suggested that in a recent PM.
    The c191 uses the same pins as c101. If you get a pin release tool, you can easily re-pin the connector provided the plastic case is on ok shape. Most of the time I see them with some sort of aftermarket connector. This connector have been a problem spot for s few years now. :/
    Yea I think you did too...
    I tried to drive it back into the garage last night when I was sort of motivated to work on it and it won’t even start now... lol
    I have a tool to de-pin that connector and also a fancy crimper I bought when I was doing my 24v swap but I don’t have any new pins and I don’t know if there’s any place locally that can get them to me quickly. Looks like work will be an interesting day if no doing any actual work :rofl:
    Im guessing I’ll need both sides to do it right, which ones am I looking for?
    61-13-1-376-191
    61-13-1-376-193
    61-13-1-376-195
    Simon
    Current Cars:
    -1966 Blue Boat
    -1969 Red VW
    -1986 White BMW
    -2006 Green Thing
    Make R3V Great Again -2020
    • ForcedFirebird
      • Feb 2007
      • 8300
      Have a car in the shop right now with the same issue. Went to start it to pull in shop, no dice. Open the c191 to see the male pins are black and female are green with white fuzzies on it.
      Since you have the tool, start by pulling the pins and seeing if they can be cleaned.
      On the phone atm, can look up those pin numbers when on a pc. Just wanted to share to let you know, you aren't alone lol.
      EDIT: And now the fuel line just burst under the tank. :/ Never ends....
      john@m20guru.com
      Links:
