Hard Hot Start... Sometimes
  • PDXPeter
    • Apr 2018
    • 225
    Curious if this is a common problem or not. Occasionally my 325i seems to have no fuel in the line after being driven till warm and then shut off for 15-30 minutes. It feels like the fuel line is just empty. Once it does kick over it runs fine.
  • jeffnhiscars
    • Jun 2011
    • 6011
    I had a weak fuel pump that died as soon as the car reached OT.
    Alice the Time Capsule
    • PDXPeter
      • Apr 2018
      • 225
      I was worried about that. Fortunately I have a spare. Guess its time to look into swapping it. It only seems to do it on really hot days.
      I did find some reference to a commonly failed valve downline near the pump. Couldn't verify the info though so I stopped pursing that idea.
      • noid
        • 1537
        Does it just crank for a while and then start and run normal? If it sits for longer (hours or overnight) it starts with little cranking?
        If so, I have experienced this with numerous E30's, I have chalked it up to being normal.
        Probably a sweet spot between the default and live maps in the ECU, mixed with various other variables which an 80's ECU is trying to figure out.
        Your resource to do-it-yourself and interesting bmw and e30 stuff: www.rtsauto.com
        Your resource to tools and tips: www.rtstools.com
        • PDXPeter
          • Apr 2018
          • 225
          Thats it exactly. Doesn't really cause a problem, just annoying when it happens. I figured its probably related to some tired part that could stand being swapped out.
          • MrBurgundy
            R3V Degenerate
            • Mar 2012
            • 5596
            Probably a weak pump, or even a leaky injector.
            Smell your oil, if it smells like gas, it's most likely a leaky injector.
            • 15Michaeljoseph
              • Aug 2013
              • 1693
              Fpr?
              Sent from my moto g(6) using Tapatalk
              (OO=[][]=OO) For Life
              • D.Martijn
                • Sep 2016
                • 1024
                I also had hard starting problems when letting it sit for a couple of hours.
                Turns out it was the fuel pressure regulator dripping into the vacuum line that goes to the inlet manifold. Causing it to start without fuel pressure and very rich.
                1990 325iX Touring - November 2018 R3V Car Of The Month
                1980 Volkswagen Golf mk1 1.1
                1974 BMW 2002 Touring
                Instagram
                • noid
                  • 1537
                  This has happened on E30's that had new OEM pumps, filters and new OEM FPR.
                  Think about it guys, if it were a weak pump, or a loss of pressure in the fuel system, it wouldn't start up without issue after a few hours/overnight.
                  • berndt
                    • Mar 2016
                    • 104
                    I have the exact same problem. I’ve swapped injectors but that didn’t fix it. Now I suspect it’s the FPR, but I’ve also just learned to live with it. Starts up on the second crank every time.
                    • jeffnhiscars
                      • Jun 2011
                      • 6011
                      Bentley says a fuel pump can cause a hot no start and that was exactly the cure in my case. I suspect as they come close to being completely worn out, they are ok cold but after expanding they can bind.
                      Mine would ALWAYS start cold and over the course of several months went from always dying when hot and being able to restart in minutes to not being able to restart at all til it cooled down. Repeated dozens of times.
                      • noid
                        • 1537
                        Right, but this is a different issue. This isn't a case of the car dying while running.
                        This issue is a matter of restarting after its been shut off.
                        Its not even really a traditional hot start issue, because restarting shortly after shutting off wont produce the problem, nor will waiting multiple hours, nor overnight, nor will it always happen, and it will always start with prolonged cranking when it is happening.
                        Its a hard start problem, when mostly hot, but only during a sweet spot in time.
                        • jeffnhiscars
                          • Jun 2011
                          • 6011
                          So many details to track in these threads.
                          My earliest symptoms were a hard hot start after stopping and not dying while driving. Eventually it progressed to dying and not starting when hot.
                          We are probably saying the same thing :)
                          • Kershaw
                            • 11822
                            Yep, seen this. Might be an ECU issue, might be an overheated ignition coil, might be any number of issues. Most likely a combination of issues. Very common. As stated before, there's a sweet spot of 15-60 minutes that it happens. Only during this time will the car experience hard starts.
                            I've thrown dozens of parts at this on a former friend's e30. Every time we thought it was gone, it wasn't. Whatever, it's not a big deal.
                            Sent from my LG-H872 using Tapatalk
                            AWD > RWD
                            • PDXPeter
                              • Apr 2018
                              • 225
                              I may have potentially stumbled on the solution in my case. I was installing new plug wires when I noticed that the MAF cap was loose. As it, I could pick it up and see the internal workings of the sensor. AFAIK this is supposed to be a sealed unit so I cleaned it up and sealed it with some RTV. Since then Ive been in several situations where it could have had a hard start and its fired right up.
                              Could have been the plug wires too... maybe. They were pretty old.
