Hard Hot Start... Sometimes
  • IS300E30
    • Apr 2009
    • 408
    #31
    Originally posted by laidback93
    1990 325is. I have this same hot start issue very rarely, but it happened last week which surprised me because it's been a long time. I went into CVS for about 10-15 minutes so I guess I hit that "sweet spot".
    I have new injectors, FPR and a couple year old fuel pump. I replaced the OEM fuel pump about 4 years ago and the check valve failed on it within a couple months. Bad batch of aftermarket fuel pumps is what I heard from several sources.
    Anyways, I've chalked it up to normal behavior as you have done too.
    Are you saying the fuel pump from a bad batch was the cause of your hot starting issue?
    • tomstin
      • Mar 2015
      • 569
      #32
      What is the condition of the fuel tank? I recall a discussion years ago where there was a lot of debris in the tank. When the car ran for awhile, or the fuel was low, the debris would collect on the pump sock and clog. After the car sat, the debris would disburse and the car would run fine until the next time.
      2004 525i Manual - 1985 325E Coupe Manual
      • IS300E30
        • Apr 2009
        • 408
        #33
        My fuel tank is new
        • 82eye
          • Jan 2009
          • 2095
          #34
          spectra or delphi - don't remember which - had a couple bad years. the check valve inside would fail and cause issues. both spectra and delphi are aftermarket jobber parts, but both manufactured for other brand names as well. i don't think it affected oe brands for the e30, but if you replaced with one of their pumps you could run into problems.
          • IS300E30
            • Apr 2009
            • 408
            #35
            If my mechanic checked the fuel pressure and it held. Could the check valve in the exterior fuel pump still be bad?
            Or if he checked the fuel pressure at the rail and the fuel pressure held, that then would eliminate any concern of the fuel pump being bad (or the check valve inside being bad)?
            • IS300E30
              • Apr 2009
              • 408
              #36
              Anyone with this issue recently changed your Air Flow Meter for a refurbished one and this then started to occur, or adjusted your Air Flow Meter and then this started up?
              • moatilliatta
                • 6152
                #37
                "Pump-Prime" The Pump-Prime feature automatically runs the fuel pump for up to 3 seconds when the ignition is switched to the "On" position. This builds optimum fuel pressure before cranking the engine, insuring your Porsche starts as fast and as smooth as it possibly can. “
                @Zakspeed_US
                • laidback93
                  • Nov 2016
                  • 435
                  #38
                  Sorry, just saw this.
                  The bad pump and check valve caused a more severe cold start issue. It would be a bitch to get it started while leaving work at the end of the day.
                  The hot start issue hadn't popped in a long time after I replaced the fuel pump again. But then it did again recently which surprised me. Always during that 10-15 minute window. Any shorter or longer than that and she fires right up.
                  90 Bronzit 325is
                  16 Black Sapphire 340i M Sport
                  • SpecM
                    • Oct 2005
                    • 4531
                    #39
                    Yup, mine does this, maybe 1 time in 3, but always in the 10-30 minute window. Starts and runs like a champ otherwise.
                    '87 325is, new fuel tank and converted to single-pump (new VDO unit), rebuilt injectors but older FPR
                    1989 cirrisblau-metallic 325i
                    • e30m3s54turbo
                      • Jun 2010
                      • 3290
                      #40
                      Originally posted by D.Martijn
                      I also had hard starting problems when letting it sit for a couple of hours.
                      Turns out it was the fuel pressure regulator dripping into the vacuum line that goes to the inlet manifold. Causing it to start without fuel pressure and very rich.
                      Thank guys.
                      I had bad adjustable fuel pressure regulator. The vacuum line was pouring fuel into vacuum line. That’s why it was running rich.
