M20 Crankshaft Position Sensor
  • zaq123
    • Jul 2016
    • 1560
    p/n 009110521
    any issues with Hella unit? People seem to recommend OEM and by looking at them both, looks like Hella was OEM supplier...no?
  • zaq123
    • Jul 2016
    • 1560
    no one ever tried Hella unit?
    • D.Martijn
      • Sep 2016
      • 1024
      Isn't Bosch supposed to be OEM?
      Either way, Hella is also a quality brand so shouldn't be a problem I guess
      1990 325iX Touring - November 2018 R3V Car Of The Month
      1980 Volkswagen Golf mk1 1.1
      1974 BMW 2002 Touring
      Instagram
      • betz
        • May 2016
        • 317
        I just got the Hella CPS off rockauto for friggin $43. What a deal. Looking into it, Hella was OEM on pretty much all future BMW's. I can see Facet or Febi or whatever being junk, but it's hard to believe the Hella one will not perform.
        I wonder if the Hella ones are a recent thing... I've never seen anyone else mention it.
        '86 Burgundrot 325 2.8 stroker.
        Other cars:
        2000 Porsche Boxster
        2006 Subaru Outback XT 5MT
        1972 Porsche 914
        • Cayoncrusier93
          • Jan 2013
          • 204
          I picked mine up from the dealer. Came in a metallic baggy and was a bosch unit. I figure i’d spend the extra money for the insurance of having the best part possible since it’s pretty crucial to the car running properly.
          • Reichart12
            • Aug 2012
            • 2165
            The plastic cased ones in my opinion do not last. This at least includes Febi. I went through several CPS with my Megasquirt m20 stroker.
            Instagram: Reichart12
            • Cayoncrusier93
              • Jan 2013
              • 204
              The sensor that protrudes incased in plastic? Mine was metal from the bracket hole forward.
              • Reichart12
                • Aug 2012
                • 2165
                What you have is the right kind. The febi is black plastic (after the bracket hole) with a circular sensor part sticking out of the end.
                • digger
                  • Nov 2005
                  • 6194
                  it might not be the sensor but MS ability to "detect" it. it seems like a common issue. i've used a plastic sensor for 10 years without issue, could be luck though. having said that i would buy an OE one next time but last time i didnt want to wait, so aftermarket it was
                  • ak-
                    • 12422
                    Which did you purchase that fixed your issue?
                    1991 325iS turbo
                    • Reichart12
                      • Aug 2012
                      • 2165
                      Yeah I can believe part of my problem was through MS.
                      I ended up buying one labeled as Genuine. Was about twice the price iirc.
                      • zaq123
                        • Jul 2016
                        • 1560
                        I did some research and it looks like Hella is OEM sensor, at least on my 90's M20. New Hella sensor has the same symbols as OEM one but BMW symbol on the sensor and BMW word on the plug are melted off. 1/3 price of OEM which is nice
                        • betz
                          • May 2016
                          • 317
                          So I got mine (Hella CPS off rockauto) and installed it and it works perfect. The only thing is that, even though the pictures showed it as the metal ones like OEM, it has the plastic cap with the metal dot at the end like the aftermarket ones. It is definitely a hella part though, came in a Hella box and has it printed on the wires. Time will tell if it lasts but... Seems to work great. Shoot, if the OEM BMW is $170, and this Hella one was $43 (~60 now), I'd have to go through about 4 until the cost equalizes. and it takes like 20 mins to install. Seems like a no brainier to me unless it craps out before the year ends. Which is very doubtful since it's an OEM brand.
                          Other cars:
                          1972 Porsche 914
                          • Cayoncrusier93
                            • Jan 2013
                            • 204
                            I paid around 120 for a dealer part (friend hook up) so for me it was worth the extra money. But hella is usually good so it should be okay.
                            • E30-Ellerman
                              • Oct 2015
                              • 212
                              Do you have the part number or know which one you went with? I'm having problems with my m20 turbo on megasquirt. So far I've tried American Standard and Meyle which are both junk.
                              Thinking of getting a Bosch or just going to the dealer and getting an OEM one there at whatever the cost is.
                              Also, what issues were you running into? I can't rev past about 5k rpm, bounces like it's hitting the rev limiter.
                              2016 F-150
                              1987 Royalblau 325es B25 turbocharged
                              Build thread here: http://www.r3vlimited.com/board/showthread.php?t=405594
