CEL comes on and off...
  • mazzo
    • Jul 2014
    • 264
    After driving for 20+ mins. It occurs randomly regardless of driving status or road condition (full throttle or not, uphill / downhill, flat road, etc.) - it just random comes on and off. However, the CEL does not cause any chocking or bucking at all, no lost of driving performance that I am noticing.
    Code say Lamba but my O2 sensor is new. I checked my boot and tube and there is no crack. My crank sensor is new and AFM had just been refreshed.
    I am thinking beside smoke test, should I try to change my TPS and check / update C191.
    Any other things that I should look into?
    Current:
    '88 325ic Silver 5sp
    '17 Subaru Outback 3.6R
    Past:
    '14 Rav4 EV (with tons of torque!)
    '06 325i Black 5sp
    '02 S4 Avant Black 6sp
    '00 Boxster Silver 5sp
    '98 New Bettle Yellow 5sp
  • MrBurgundy
    R3V Degenerate
    • Mar 2012
    • 5575
    no need to change the TPS unless you know its not working.
    I'm assuming you pulled the code via a stomp test, so if you car is idling okay and a stomp test works, you're TPS is most likely okay.
    • HerbE30
      • Nov 2015
      • 538
      Ensure you have the correct gap on the new CPS.
      20% Accurate
      Morty: Well Summer maybe people that create things aren’t concerned with your delicate sensibilities you know? Maybe the species that communicate with each other through a filter of your comfort are less evolved that the ones that just communicate? Maybe your problems are your own to deal with and maybe the public giving a shit about your feelings is a one way ticket to extinction.
      • majdomo
        • Jun 2018
        • 449
        Is your CPS aftermarket or OEM / genuine? I tried an aftermarket one and had it fail after about 3 months of use. OEM one has been in the car for about a year with zero issues. Only crap part is how expensive the OEM one is.
        Current flame: E30 318iS Alpinweiss II slicktop / LSD - Joanne
        The old man: 1970 2002 Polaris(ish) slicktop / rat rod - Wallace
        The ex: E92 335i 6MT M-Sport - Betty
        The heavy: 2001 4Runner SR5 Sport (3rd Gen) - Fred
        • mazzo
          • Jul 2014
          • 264
          How to ensure CPS gap is correct? Thanks!
          Current:
          Past:
          '06 325i Black 5sp
          • HerbE30
            • Nov 2015
            • 538
            Take a feeler gauge and measure the distance, should be about 1mm +/-.3m. If I remember correctly.
            20% Accurate
            • mazzo
              • Jul 2014
              • 264
              ok Thanks.
              Current:
              Past:
              '06 325i Black 5sp
              • mazzo
                • Jul 2014
                • 264
                Ok - report back on crank sensor check. I finally took the time to get a feeler gauge and checked, and the space is right.
                I am out of idea on what to do - again this does not happen when I am not moving the car (even when I step on gas to WOT at stop). This only happens when the car been driven for about 20 to 30 mins.
                Any idea?
                Current:
                Past:
                '06 325i Black 5sp
                • e30davie
                  • Apr 2016
                  • 1788
                  Got any history on the fuel pump?
                  The 20-30mins.thing reminds me of an fuel pump that would work fine for 20mins then then car would start spluttering. If you let it sit for 5mins you would get another 20mins out of it.
                  I wonder if the fuel pump is slowly losing fuel pressure over half an hour causing a lean mixture which shows up as a cell for the o2 sensor. Maybe it's not bad enough to cause driveability issues but does cause lean condition. Just a theory.
                  • mazzo
                    • Jul 2014
                    • 264
                    The walbro 255 was installed about 25k miles ago. I hope that is not the cause of it, but just in case, how should I check it? It's hard to detect since I did not lost any drivability (both city and freeway, partial or WOT) when the CEL was flashing on and off random. I also did not experience any bucking / stall / rough idle at all so this makes diagnostic difficult..... :)
                    Current:
                    Past:
                    '06 325i Black 5sp
                    • ZekeTheSneak
                      • 1562
                      Have a harbor freight near by? They sell super cheap fuel pressure guages with a few fittings. Disconnect the inlet on the fuel rail and install the guage with the t fitting. The inlet is the front of the rail. The fpr is always at the back of the rail. Then connect the other end back to the rail. Should be around 3 bar of pressure.
                      • e30davie
                        • Apr 2016
                        • 1788
                        Or i wonder if you have an exhaust leak that is playing havoc with your O2 sensor.
                        • mazzo
                          • Jul 2014
                          • 264
                          @ZekeTheSneak - I have fuel gauge installed and the pressure looks normal to me (I have it at 3.5 bar, using 19# injectors and SSSquid chip on M30 AFM)
                          @e30davie, if that's the case why would it not show up until after 20+ mins of driving. I tried to rev my engine constantly up and down between 3k to 5k for well over 5 mins on my drive way but I can't reproduce it....no CEL.
                          But just in case, any way to check where the leak exist?
                          Thanks in advance!!
                          Current:
                          Past:
                          '06 325i Black 5sp
                          • mazzo
                            • Jul 2014
                            • 264
                            @ZekeTheSneak, sorry forgot to mention I have the adjustable FPR with gauge installed since I have these mod for well over 2 years. Never touched them since. Thanks!
                            Current:
                            Past:
                            '06 325i Black 5sp
                            • moatilliatta
                              • 6151
                              What is the actual fault code or do a stomp test?
                              @Zakspeed_US
