Coolant leak off the back of the block
  • 2ohoh2
    • Apr 2016
    • 16
    So I am doing an m20 swap into a '74 2002. I got the notice in and to run and I just finished the coolant lines, filled her up with fluid, and then it started leaking out the back of the motor. I can't quite tell where it is coming from ( does not seem to be the heater hose at the back of the block) but it is dripping slowly at the bottom of the block by the transmission (attached photo) Any ideas?
    Thanks in advance
    Sent from my SM-G920V using Tapatalk
  • IRON-E
    • 16548
    Did you replace the rear main seal and what kind of bolts are those at the bottom?
    @IRON-E30 aka Edwin:D
    • 2ohoh2
      • Apr 2016
      • 16
      I did not replace the main seal before I installed it... And the bolts are replacement trans to engine bolts that I got from a auto website, don't remember which one at this point, but something like ecs or pelican
      • Cayoncrusier93
        • Jan 2013
        • 204
        Are you running lines to your heater core? Freeze plug on the rear of the head? Gasket for heater core hose adapter plate on rear of head? Loose hose clamp on heater hose that attaches to rear of head?
        *I don’t understand how a bad rear main seal would leak coolant? I thought those sealed the oil inside the engine?
        • IRON-E
          • 16548
          You're right, I misread this whole thing.
          • 2ohoh2
            • Apr 2016
            • 16
            It does not seem like it is coming from the heater core adaptor plate on the back of the head or any of the heater core hoses. Maybe the freeze plug on the back of the head, but I'm not sure where that is and have been having trouble finding a clear photo of that. (Currently traveling, so I can't poke around right now) Anyone have an image of where the freeze plug is?
            • uturn
              • Dec 2010
              • 1001
              Freeze plugs are on the block, if leaking at the one on the back, you'll have to drop the tranny to get to it.
              • Kershaw
                • 11822
                That pipe that's peaking out at the end is the coolant exit pipe for the head. Check around there.
                AWD > RWD
                • BMW_325i
                  • 61
                  Have you noticed any coolant leak anywhere on the engine previously, and was the engine or car raised at the front when you saw this drip?
                  I have had a very slight leak from thermostat housing for a while which took a while to locate.
                  When i jacked up the engine to replace the oil pan gasket i found a coolant drip around that location which freaked me out - thought i had broken the coolant exit pipe mentioned in above threads.
                  But turns out it was just the leak from the front making its way along the engine and gearbox while it was jacked up for the day.
                  1988 Lachssilber E30 325i sedan.
                  Factory fit-out: manual; SILBER LEDER; M SPORT SUSPENSION.
                  Modifications so far: Miller MAF + 19# ECU; Ford 19# Design 3 injectors; IE adjustable FPR; KAMotors CF airbox; IM MTX-L; EBC Greenstuff.
                  Retired - '83 Arctic Blue E28 528i powered by M30B32
