Testing Ignition Coil - What’s the proper resistance?
  • Andrew325is
    • Jan 2008
    • 1212
    Bentley manual says 0.50 ohms for primary resistance and 5000 ohms for secondary resistance. I tested my coil and it’s 1.2 ohms primary and 5700 secondary. Bentley manual says to replace if higher than the listed values so I got a new Bosch coil. New coil tests 1.2 ohms primary and 6600 ohms secondary. Tested with 2 different Fluke multimeters. What does it mean? Are both bad or is the old one okay?
    Plug and Play Wiring Harness Adapters for S54, S50, M54 and more.
  • digger
    • Nov 2005
    • 6102
    Why are you texting coils on first place? When I tested mine years ago it didnt match with bentley either but there weren't any issues. I'd say it's fine
    • Kershaw
      • 11822
      I bought 2 new ones and it was nowhere near spec in the Bentley. It's fine.
      AWD > RWD
      • Andrew325is
        • Jan 2008
        • 1212
        Refreshing everything and the old plugs have carbon deposits so I thought I’d test the coil.
        • Andrew325is
          • Jan 2008
          • 1212
          I found your thread about this here: https://www.r3vlimited.com/board/sho...d.php?t=376659
          So I guess the new coil is fine. To test the old one it looks like I'd need to use an oscilloscope.
          I looked up how to test it in the factory E30 repair manual and it has a 3 step procedure:
          1. "Multimeter Test: Measure resistance of primary coil - term. 1/15 = 0.5 ohm +-10% and secondary coil - term. 15/4 = 6k ohms +-10%."
          2. "Inspect connection plate for hairline cracks and traces of burning. Check plug (S) for tight fit - replace ignition coil if it is pressed out."
          3. "Connect BMW Service Tester on diagnosis socket. Run engine test step 09. Observe oscilloscope - ignition voltage = 6 to 14 kV. Check ignition voltage deviation = < 3 kV."
